Epp air filter
Shokev
Philadephia
Where can i buy another air filter for the epp set up ?
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
No I don't think they found a sock that fits, I think @FiveLeeter918 has a sock that he cut to make fit.
Mine is a direct fit for the Gen 1 filter, I haven't attempted to make it fit a Gen 2 filter but Mike says it will not fit. Not sure which dimension is off.
Zpak
Es Aich Oh!
The region, Indiana
No it won’t fit, I cut the elastic and made a small slit on the big end to make it over. Sorta defeats the purpose, but it is covering most of the filter.
BD971079 E55A 48FE BEAC CDE8F7D85B48
gwrabbit
Wisconsin
Yeah, I don't use oil in my K&N filter either. I usually find that whacking it against a fence and vacuuming it with a little handheld vac works best.
FiveLeeter918
Tulsa, OK
yep no oil here. I occasionally rinse it in water with the cleaning spray they offer, but no oil. Just let it dry overnight or stick a hair dryer inside for 20 minutes then slap it back on.
Zpak
Es Aich Oh!
The region, Indiana
Zpak, what size (p/n) sock? Hey, it's covering the area that takes the most abuse, that's better than nothing in my book.
It’s the one (at least at the time I got it) linked to from EPP. I think it listed it as bronco.
