Original leather-wrapped steering wheel cover template for you
NoSlo
SHO Owner
Portland, OR
Before tossing a G2 steering wheel in the dumpster, I thought I would strip the leather off, scrape off all the adhesive and glue, shave it down to rawhide, iron it to shrink the stretched areas, and make some scans so you can peel off the old one and make a new cover.
half still with the impressions from wrapping around the spokes, half cleaned and flattened:
GrB2cmv
When I put it in my 8.5 x 14 flatbed scanner:
6qBTo7y
When I make a template based on this:
VujCvll
PDF file so you can print at correct size: sho-steering-wheel-template.pdf (739k) - be sure to print at 100%, not "shrink-to-fit".
The wheel has a core of foamy plastic, but between the leather and the wheel is another layer of 1mm rubber. Either you need to carefully preserve this while peeling, or remove it all, or spots might show through. The whole leather cover is glued to the wheel, with especially tacky glue on the spokes - use special leather glue for these parts.
It is possible to use two or three shorter pieces of leather if you wanted to add seams to construct the large piece. You'd have to carve a slot in the wheel like the other seams have to avoid bulging.
For installing, there's tutorials of the "baseball stitch" online. Use thick polyester thread for upholstery.
(you can also just sand down the wheel leather and repaint (with SEM presidio gray) after disassembly for a temporary fix)
yaycandy
Aerospace Engineer
Hanover, PA
Took mine to an upholstery shop. Under 100$ and its literally new and i didnt have to do anything. Something like that in my mind is stupid to do when a shop can do it for alot less then i could myself and quicker than i could also
NoSlo
SHO Owner
Portland, OR
I guess it depends on if you like your job so much more than paying yourself $20/hr for taking pride in your car.
$20 plus environmental fees and gas to another state and it's replaced with a like-new one...when somebody wrecks their low mile SHO.
yaycandy
Aerospace Engineer
Hanover, PA
Theres plenty of pride in my car. Almost 10k with the body work and interior work on my 90. Was a perfectly running car when i bought it in March.
Wrapping leather. Yea leave it to the professionals in my opinion. You also cant get the correct leather on your own without a company account, i tried
crystizel
