My Build Project for "Bewsted SHO"
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Interesting. Want to hear more on this.
It's actually this one.
https://www.deatschwerks.com/9-307-1026
the DW400 linked above was too big for the stock bucket and required many modifications from what I hear. This is a drop in and includes the harness (have to specify for the SHO when you order).
Turns out it will be here Thursday, so we'll see what happens.
CCXVI
It's great to see a full thread about yours, definitely wanna see what that new pump does for you.
FiveLeeter918
Tulsa, OK
I'm bad about build threads haha. So I got the DW pump in, went to install it and nada. Too big, electrical connector was wrong, yada yada. So I bought a new bucket, sent it and the DW pump back to them and they installed it for me. Unfortunately with finished my engineering degree it just sat, and now I'm working form home with my wife and 2 kids and somehow have LESS time than I did when I worked 45 minutes from home 9 hours a day haha.
So a few updates since I last posted:
Upgraded the SHO to R1Concepts slotted brake rotors and Wilwood 6 Piston brakes. These things are insane compared to stock, and mixed with semi-metallic pads it stops way better than the PP pads did. I have a full write up on this in the performance section and will be offering this on our site soon.
91333482 2820920907993137 7257768945191485440 o 89657979 2772243006194261 8307410045541285888 o 89527619 2772242822860946 2557951340311478272 o
I also felt a little rice in me so I installed the Spoiler King roof spoiler. Was a bit of a pain to line up, but I think it looks good.
91394317 2816933531725208 7310005153489223680 o
94234925 1347397422137858 5796292153906823168 n
I also re-did my grille in satin black and added a CCG XXL Grille in place of the factory honeycomb.
83838177 2701052779979951 6215092937471033344 o
84042121 2701052839979945 4727703775265947648 n
FiveLeeter918
Tulsa, OK
A pic of the rear brakes since I ran out of pic attachments. I'll be painting them blue to match the fronts, but was waiting on more G2 paint since I did the fronts off the car. The brackets will stay black, only the caliper itself will be blue.
94610254 525400631680406 3822032139046617088 n
FiveLeeter918
Tulsa, OK
Also decided to turn my attention to lighting for a bit, and call on Limitless Concepts in Tulsa, OK to search their catalog for full LED replacements on the car.
So far I've installed:
* License Plate Lighting
* Reverse Bulbs
* Puddle Lamps
* Map Lights
* Rear Dome Lamps
* Switchbacks
The switchbacks for some reason still hyperflashed in select scenarios, like unlocking the car WHILE RUNNING and when I had DRLs activated in Forscan. Otherwise they are flawless so trying a hyperflash module to keep from having to splice resistors since these already have the resistors built in.
I also took delivery of some extra bulbs today to do the front corner markers, the trunk, the vanity lights, and a few others. Should have pics of those when I get some free time.
80871798 2636571473094749 2590270045795909632 o 81686382 2636571549761408 4857226287967633408 o 85051229 2713428788742350 7913496480038518784 o 85110459 2713428852075677 185991303895449600 o 84671461 2713428925409003 5941356843287707648 o 89893487 2785662054852356 7157238316436291584 o 89042621 2785661918185703 6664042922574348288 o
FiveLeeter918
Tulsa, OK
My final update for now (I think) is that I've finally decided to venture from the stock catback. For the past year, I've had catless downpipes and the stock catback and while I do like the sound, I want a little more agressive tone without being raspy or obnoxious.
Last week, I ordered a Magnaflow resonated X-Pipe and some 2.5" and 2.25" flanges. My plan is to continue 2.5" flanged piping from the downpipe connection into the X-Pipe, out of the X-Pipe, and then neck back down to 2.25" for the "Axle back" connection. At this point I may or may not add a flanged connection like @SM105K, jury is still out even though I went ahead and bought the flanges and gaskets.
Also, since I first bought this car I have always thought it should have come with Quads. If the GT500 can come with quads why couldn't the SHO? Haha. I decided to buy a cheapish set off eBay to test with, since I want to keep stock mufflers the main concern was the point at which the bumper starts to brake over and didn't want it sticking out.
First set purchased:
94233953 590722588209033 7669575962924679168 n
However, my fear was confirmed, as these would stick out about 1" past the brake over point. After doing more searching, making calls, and taking measurements, I found these:
94317949 244537480089845 7338904034213888000 n
The angle of the tips matches the SHO bumper almost perfectly, and by mounting this in the stock tip location I'll be moving INWARD instead of OUTWARD which will accomplish my needs. I realize the second tip will likely do nothing, but at least it will look cool haha.
FiveLeeter918
Tulsa, OK
With COVID the car has been pretty stagnant, I've done a few things that I'll update on.
For one, I got some of my photoshoot photos back from my buddy testing out his new camera at the Mid America Ford & Shelby Nationals. I volunteered most of the week but did decide to get in a few runs at the track event. Nothing crazy, it was bracket racing so I put in my neutered tune for consistency and ran 12.7s all day with 14 psi and 16 degrees of timing on 91. Put the E30 tune in after I was eliminated hoping to get some glory runs but they decided not to do TNT and shut the track down after eliminations. ****...
Car is looking great though, not sure I have anything else to do in the engine bay...
107639865 4131632256210 7512647600877711728 o 107698772 4131636936327 3186505937266979901 o 107767234 4131626656070 3148719024063022408 o 107828252 4131630496166 353345670356823207 o 108382772 4131635456290 6363218963833648225 o
FiveLeeter918
Tulsa, OK
Also got most of my engine caps installed. Got a set of covers from an 11-14 GT, used a dremel to clearance a few pieces and it went on with a dab of epoxy. All thats left is the coolant cap, the black was discontinued so I got them cheap but the coolant was out of stock so got chrome. Gotta sand and paint it.
Planning to dip the engine cover soon and then do a few other accents to compliment the calipers.
What else should I do? I originally wanted a sleeper but with car shows I want more pop. I bought blue couplers to update the look, just need some extra time to pull everything and replace.
20200710 095926
FiveLeeter918
Tulsa, OK
The day after Mid America I had a blow out on my 245s, so figured what the **** and upgraded to 275/40/20s... who doesn't like more meat?
20200710 101120
Michigan-SHO
Michigan
I think a legit next step for dress up is new hardware. Nuts and bolts and changing out hose clamps.
SuperPete
PA
View attachment 12879 View attachment 12880 View attachment 12881
LOVE THE GRILL, where did you get that?
Thank you
