Transmission/PTU cooler for non-PP?
deltch
Texas
Is it possible to mod a non-PP SHO for better reliability on the PTU/Transmission?
I'm curious if this has been done before or not, and if so what did it cost and what parts were needed?
yaycandy
Aerospace Engineer
Hanover, PA
I tried an aux cooler. Didnt work out well in test drives. Lines are replaced with plugs now. Just change the ptu oil twice a year or at every oil change if you are real picky and run a good expensive oil in it. I run amsoil severe gear
If your ptu goes out, replace it with the pp or pi package one. Just need bottom radiator hose and hookups from ford to feed it and also the engine oil cooler that can be bought and fed off the same radiator hose.
merp
Flower Mound
I know I'm resurrecting an older thread, but are the PTUs a direct swap, minus the lines and cooler?
Iqoniq
Atlanta, GA
As far as I can tell, yes.
*disclaimer: Opinion formed from scouring the internet.
Ryan Selcer
Colorado
Do the older *2010-12* gen 4 PP have coolers on theirs? I guess i need to crawl up under there and look lol
2010 SHO PP, axle back exhaust, 3 bar MAP, upgraded thermostat, iTSX tuner, 20" summer rims
Ryan Selcer
Colorado
The coolers started in ‘13.
That was my understanding but I saw some people just saying PP so I wanted to make sure, so the non-pp post 2012 are also not cooled
sdoherty
Virginia
This is somewhat related but on cars with the factory integrated PTU water cooler the radiator has a ****** on the drivers side under the main feed. I have been unable to find this radiator - anyone have a p/n or source?
Texas Marauder
Lone Star State
Assuming you are talking about the drain, the difference appears to be between with oil cooler and with out oil cooler.
Without oil cooler
Screenshot 2025 02 20 123358
With oil cooler
Screenshot 2025 02 20 124016
Note that Motorcraft lists 4 different radiators. This is for 2015, other years may be different.
Screenshot 2025 02 20 124311Screenshot 2025 02 20 124413
sdoherty
Virginia
This is what I have - the small inlet or outlet goes to PTU.. bottom of radiator drivers side..- oh yes this is it the bottom one - thanks!
