Rear Differential Fluid (AWD) vs. PTU Fluid (AWD)
Isaac Shea
Honolulu, Hawaii
Aloha guys,
So I'm looking for a mechanic to change the differential fluids in my 2015 SHO, but I'm a little confused about the specifications. There's Rear Differential Fluid, which asks for (2.4) pints of 80W-90 Premium Rear Axle Lubricant, and there's also PTU fluid which asks for (180z.) 75W-140 Synthetic Rear Axle Lubricant. So which fluid goes where when they both say "Rear" ? I'd like to find a mechanic I can translate your wisdom to as Ford service in Hawaii wants to charge me $500...I told them for an oil change you can go to ****.
Thank you!
Shokev
Philadephia
Aloha guys,
Thank you!
The 75w goes in the ptu
Isaac Shea
Honolulu, Hawaii
Thank you! And that's the smaller box in the rear. So the 80W goes in the front? They should put something in the manual for ignoramus like myself..
It IS stated in the owners manual what goes where. But it IS also confusing when they call it REAR axle lubricant, but that is due to what the fluid was originally developed for and the dominance of RWD at the time. A lot of nomenclature comes from what was in use a century or more ago.
jman1200
Ontario
No.
The PTU (power transfer unit) is the one located in between the front axles (right under your feet) and uses the 75-140.
The RDU (rear differential unit), located in between the rear axles uses the 80-90.
ShogunofHarlem
Missouri
Aloha guys,
Thank you!
My local dealer just charged me $67.00 for ptu fluid change. Differential was around 150 if I recall correctly.
Joshw0000
North Carolina
The PTU is in the front (75w-140 - 1 quart) and the RDU is in the back (75w-90 - a little more than a quart). I put Royal Purple in mine but Redline and Amsoil both have great reviews.
If you line up your front tires perfectly and shine a light through, you can see the plug for the PTU through your front right rim. That's how I got to mine, with several socket extensions.
And the RDU is a little easier to access in the back with a low profile socket.
Isaac Shea
Honolulu, Hawaii
The transmission guy I went to siphoned out and replaced with 1 quart 75w-140 Royal Purple in the back RDU. I hope the 80w-90 can go in the front PTU... Thoughts?
Joshw0000
North Carolina
I wouldn't drive it much until you (or someone) can siphon the RDU and put the correct weight back in it. And I definitely wouldn't put lighter weight in the front. The PTU is surrounded by heat. 90 weight wouldn't protect it very well once things heat up.
Isaac Shea
Honolulu, Hawaii
Isaac Shea
Honolulu, Hawaii
Okay, and thank you again for the information. I have not yet replaced the PTU (front) fluid. My manual only asks for (.56) quarts of 75w-140. It seems the front should take more, but I'll roll with the factory specs.
As mentioned previously, I currently have 1 quart 75w-140 in the back RDU. My manual asks for 1.15 litres (or 1.21 quarts) so I could probably add .21 quarts extra to meet factory specs.
I'm slowly seeing why this oil change costs $500 at Ford...
Joshw0000
North Carolina
If you decide to do it yourself, you can save some money and sleep better knowing it's done right. I did mine last month.
https://r.tapatalk.com/shareLink/to...share_fid=156498&share_type=t&link_source=app
Everyone here is incredibly helpful. If you decide to tackle it, I'll give you some pro tips from a non-mechanic that'll save you some time and headache. I.e. cheap tools I own now that I should have owned before I started.
Joshw0000
North Carolina
Also note that a lot of Ford dealerships won't change the fluids at all, since they're supposedly "lifetime fluids". Or at least Ford thought so at first. That's why most of us don't have drain plugs.
Isaac Shea
Honolulu, Hawaii
Thank you so much for all the great information. I hate wasting the Royal Purple 75w-140 already in the RDU, but I guess I should stick to factory specs with the 80w-90. I'll go ahead and replace the PTU with the 75w-140...
Mahalo!
crystizel
