New member, 1989 SHO rescue
WhiteLX
SoCal
Hello all,
I recently picked up a 1989 SHO that has been sitting since May 2006. The story is it wouldn't start, so the owner took it to a mechanic and began to diagnose it. Supposedly it's a bad fuel pump. Anyway, the mechanic quit and then the shop closed up, so they towed the car back home and it sat and sat. I'll test the fuel system then begin on diagnosing any other issues.
The paint should polish up alright, I've done a few test sections. It's a repaint, metallic black. The front seats have been redone, I believe in vinyl. The rear seat needs to be redone. The car came with a stack of receipts. It has a documented 145k on it. The goal is to get it back on the road, soon. I did have to eradicate a bunny from his home under the hood. There is some damage to the wiring, but not too bad, at least from the top side. Some new pigtails and battery cables will fix it. I still need to get under to inspect the wiring and hoses. Suspension appears to be good, no rust being a SoCal car it's entire life. All but one of the tires held air, and surprisingly are still holding air after a few weeks. The spare is good too.
I'm no stranger to Fords and building them up. I've got a turbo 5.0L foxbody Mustang, a Merkur XR4Ti, and a 5.0L 2nd gen Explorer.
These pictures are from the day I picked it up, just as I found it aside from airing up the tires.
O9l8E9ioQGW0 1a759ER5A U2KXfW1 St2ImTaZoRiQEA JDArNt7rTdKFmqo7bXJ2Fg
Irish Pride
Irish Inside
MusicCityUSA
Is this the one with the flakes in the paint? Keep it out of the sunlight. Lol
Welcome to the forum.
-Chad
WhiteLX
SoCal
-Chad
yep, metal flake. It's got a cover on it now. Can't wait to do a proper detail on it. Need to get it running first though so I can get it to a water source. I really wanted to stop by a coin op wash on the way to it's storage spot, but it was late and I needed to get the trailer back.
Them varmints can do a number on the wiring. Good luck getting that patched up. Keep posting with updates. just FYI there is a shortage of crank position sensors for these cars. There is a batch getting made up so keep your eye out if you get this thing running and want to keep it for a while. Not sure how big the run will be or all the details but that info is around somewhere. Maybe the SHO facebook group.
WhiteLX
SoCal
Yes, I have been watching it. Seems like they might be about $200. Unfortunate on the cost, considering it's half what I paid for the car, but I understand it's to recoup the costs involved. I'll probably by two to have a spare.
