Msd coils
The Gemini
Ohio
Cheese & Rice. I wasn’t trying to tick anybody off. I simply had some concern after sending money to a total stranger and not hearing anything afterwards. I really don’t think that’s out of line in this day and age.
Wsho - I truly appreciate your efforts and doing this for everybody. Hopefully your internet issues have been resolved, and all is well with you. I don’t know you from Adam, so here’s to hoping you're understanding of my situation, as I am now much better understanding of yours. Again, thank you for taking the time to do this for everyone.
II
ridered74
II
Where is it that you see even a trace of anyone being ticked off?
Wsho
Sacramento California
No I'm fine I understand I would think the same thing. It's all good. Internet still a little sketchy but I'm here
Sweet I did see the tracking number pop up. Thank you sir.
Keep Alive Memory. There is a KAM circuit that provides power to computing units to save data. You auto PCM has adaptive functions based on streams of data and prevents loss of this data when the car is turned off. If you want to clear adaptive tables with previous driving inputs, you make sure all power has been purged from the system to get a fresh reset.
Wsho
unplugging the battery works? Or is there another method to do. May have a built-in capacitor to hold memory functions.
It may hold memory functions for a little while. I have owned a bunch of older SHO's and I usually unplug the battery for a little while and maybe even put a load on the electrical system and turn on the headlights or whatever.
More modern cars I am not as familiar. I have a '14 f150 but I have not had a reason to clear KAM memory yet so I don't have a great answer off the cuff, but I'm sure I could get one in quick google search. There may even be OBDII devices that can clear adaptive data tables without power interruption.
Mine arrived yesterday, and they along with new plugs are being installed today.
Wsho
Everyone should have their coil packs by end of today and one will be delivered on Monday.
I have 6 people on the list for January's order. I will only order 10 coil packs. If you're interested PM me this will be the last order I'll put in.
stripSHO
Idiot Savant
Detroit
So with these coils is it recommended to open the spark gaps at all? What about dwell time adjustments?
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
In the article they say these were tested with sp542 plugs with a .028 gap, it mentions more performance potential at .026 gap but they didn't do a gap test. I would use the same plug and gap range as their test to ensure similar results.
crystizel
