SHO Shop UDP Belts
9091SHOs
Pittsburgh
Does anyone happen to remember what the belt sizes are for use with the SHO Shop 3 piece UDPs
Thanks
Irish Pride
Irish Inside
MusicCityUSA
Belts i use are Gates K060427 21mm x 1105mm, and K040490 14mm x 1255mm but I have the 4 piece Underdrive kit so you will probably need to go slightly larger to account for your stock crank pulley. This should give you a good starting point though.
zak
east of Hartford
This is a great topic, as this data is hard to find. The 94-95 SHOshop 3 piece UDP's were different and required different belt sizes. I have tomorrow off, will check the belt numbers (have them off the car at the moment).
Which year car do you have? 1990, 1991? Both?
If you run the stock alternator belt the tensioner pulley can interfere with the battery/battery tray, saw more than one "machined" battery ruin an open track or autocross day.
9091SHOs
Pittsburgh
I do have both a 90 and a 91+. The 90 is the one in question. It has the 3-piece SHOShop UDPs. It is a 3.2 swapped car and I have had the UDP's on for a long time without any issues. It does use the 4-rib belt associated with the PS for MTX cars.
