Gearhead Tune Questions
OmaHahn
Omaha
yes you can. like I said many ways.
Just making sure. Don't think I would want to bring a laptop and sct and connect all them up and so forth. Just didn't know if there were advantages one way or the other.
tpivette89
Middletown, DE
Keep us posted if you go this route... as I am also considering a E30 tune from GH. Would love to see additional results.
Just emailed Matt, but not expecting a response until Monday. I've got a few friends running a few tenths quicker than me at the drag strip and would love to see their jaws drop when I match (or beat) their times.
76FoMoCo
Nampa, ID
I think I need a GH E30 tune for my dyno sheets for a comparison.
going to be hard to beat the AJP tune I have now as this thing runs as perfect as I can imagine. Lets hope!
High on Ethanol
Just Ain't Care
USA
I run the E30 GH tune year-round in northern Ohio. It runs flawless. You can monitor more using a laptop connection with your SCT, also seems to log at a higher resolution. I highly recommend GearHead over all other tuners because he actually tunes the entire vehicle. It doesn't feel like any other tuner. It makes the car actually feel like a 50k vehicle. Other tuners may make higher hp, but they don't make the ultra crisp shifting and they don't make sport mode feel so damned sporty. As well as other tweaks.
Matt's E30 tune is worth every cent.
OmaHahn
Omaha
I agree, even his AO Tune is amazing! When you put the shifter into S, as the car slows down the rev matching is so cool!! His tune embarrassed my LMS 93 tune both on the dyno and especially the shifting! Gearhead rules!
My AJPTurbo tune does the same thing....
High on Ethanol
Just Ain't Care
USA
AJPTurbo is awesome and I primarily use his tune when I plan on racing. It definitely has more low end and mid range pull. But it has no difference in sport mode and doesn't shift much different than other tunes.
Nothing against Brad,his tunes are awesome and he did great explaining what he was changing. If I was intent on primarily racing, I'd probably spend my time and money on his tunes exclusively.
For my daily driver, stoplight racecar, grocery getter, worklunch meeting car, etc.. etc.. I'd recommend GearHead. I didn't even realize the Taurus could feel like a true high end luxury sedan until I made the switch. The shifting makes me use sport mode almost every day. If you haven't tried it, do it. Even if you only use it for around town or long trips. Absolutely worth it!
My sport mode completely changes everything. Everything you said the GH tune does, my AJPTune does as well except my sport mode works. There is a night and day difference between drive and sport in my car. Maybe because mine is a PP?
High on Ethanol
Just Ain't Care
USA
Maybe you have lucky revision. Brad has stated he doesn't tune sport mode because it's just a pedal multiplier.
I've compared the tunes in HPTUNERS and I've seen the things each tuner changes.
The number of items tweaked varies greatly between tuners, for example Brad tunes more settings on the engine than unleashed, GearHead tunes even more than that but for different reasons I believe. The transmission settings between Unleashed and AJPTurbo are very similar but neither is even close to Matt's. Again I'm sure each tuner has their reasons for every tweak.
One of the reasons I tried GearHead was because I felt like AJPTurbo didn't have time for me. I also know that anyone here on this forum that has been GearHead tuned will say the same things about the shifting. If you experience the same style upshifting and downshifting with any other tune, you'd be the first to say so.
Also the only thing that would even apply to a PP vs a nonPP when it comes to shift tuning is the mph it shifts at due to the short-geared PP running out of breath earlier.
mattr66
How were you able to open the Gearhead tune on hpt?
OmaHahn
Omaha
@mattr66
I need to datalog and I've read the posts from these very helpful members - but I want to confirm with you how to datalog for you. I've never done this before, is this exactly how you want it?..... Livewire ts and plug it into the obd2 port and then plug my laptop into it and open live link. In my case Brad sent a config file with all the data he wants to see. So I load this file and turn off TC put in sport mode and paddle shift to 3rd and hit start log on live link. Then bring it up to about 2k and floor it to red line. save the log on the laptop and email to tuner..." I've seen others say to slow rev to limit, WOT in 2nd gear, etc.... Thank you!! I'm going to do this tomorrow (Monday) and get your E30 tune!
High on Ethanol
Just Ain't Care
USA
@mattr66
I always like to datalog from dead stop to around 100mph and a 3rd gear roll from 2k up to redline.
You can load the config file to datalog directly on your device.
Matt usually will answer questions quicker if you email him directly.
OmaHahn
Omaha
Thanks, I have his email so I''l try that.
mybigsho
new york
I have been following this tread, These two tuners are the best at the game now.. They both have there own way of tuning a car.. They shift different, sound different, and they get it done.. I have had my G.H. E30 tune , I.C. and went with a pump looking to get all I can since the spring.. I just started working with Brad AJP and we're creaping up on hitting that magical number.. I Like them both.. There great for this platform!!
subdocgtp
Chandler AZ
If you choose a custom tune and have E85 available I would opt for a E30 tune. More boost, more timing, more power. Pretty simple.
SM 105k I'm figured out how to put in a direct message here to you I'm in Arizona if you can please contact me I have a few questions for you thank you
Signal13
North Texas
How does unleased tunes stack against these two? I’m about ready to pull the trigger but unleashed has a packag that’s $100 less than gear head.
