Looking to buy power steering pump and pulley
tlcsho
93 SHO
PA
I need a power steering pump and pulley for a 1993 ATX (3.2 engine)
Thanks
Tim
Irish Pride
Irish Inside
MusicCityUSA
My step dad looked into it he found that the 3.0 and 3.2 have the same part number
The pulley is different. ATX and MTX have different belt drives. The ATX only uses one 6 rib belt. Where the MTX has a 6 rib belt and a 4 rib belt.
Night Runner
89SHO
Fort Wayne IN
Why are the part numbers the same my step dad works at Napa and the part numbers are the same. Maybe the pulleys arent? I dont know for sure but he said the the pumps are interchangeable. Maybe the pulleys can be swapped?
Night Runner
89SHO
Fort Wayne IN
More info the remanufactured pumps don’t come with the pulley posing no problem maybe the NOS with the wrong pulleys won’t work but he remans you can swap your pulleys onto them
Irish Pride
Irish Inside
MusicCityUSA
The pumps are the same. The Pulleys are not. We don't know why he's asking for both. Maybe swapping the pulley isn't an option.
NoSlo
SHO Owner
Portland, OR
I've got one. It's the original from my car when I swapped all the accessories trying to find a squeal that was ultimately a loose tensioner. I'm pretty sure I got it with the pulley, but its been in the parts tote for many years so I'd need to check.
tlcsho
93 SHO
PA
Thanks for looking, but don't spend any more time. I found a pump and pulley assembly on ebay.
