Alrighty guys
Sorry for the late update but have been working like a dog
I have cleaned out everything on the bottom end pretty good for inspection.
Nothing seems to be out of order in terms of cracks and excessive wear or damage.
I cleaned and inspected all the pan bolts and inner pan bolts as well as the oil pick up and the mains stabilizer pan and wrack with bolts.
Also cleaned and inspected the removed bearings (haven’t removed all of them yet) connecting rod caps and the starter. I don’t have a picture but I have found that the starter power connection post is stripped. Right into the base of the starter.
Thanks for the tip NoSlo Totally didn’t use the promo code as I’m new and didn’t know where to find it lol
Don’t pay no attention to the oil as I’m only going to use this cheap stuff to give the engine a thorough clean with some cleaner and then dump it for some good stuff.
I haven’t pulled the trigger on putting everything back together as I am still waiting for a couple gaskets ( oil pickup/ front and rear oil pan rubber gaskets) plastigauge pre-**** and some 600+ sandpaper for the journals.
Oh and an oil filter can’t forget that
Once I have everything I need I will be preforming most of what
@NoSlo has posted
(Thanks a bunch )
I have never used plastigauge but I will do some research before hand. Any tips will help.
I will be attempting to do all of this from underneath the car (bottom end) while the crank and pistons are still in the engine.
From my guestimations it is doable.
My shifts at work have turned into nights which makes me a zombie
and it is hard to set the body back to days which puts me all over the schedule map.
It will be done sooner than later.
Thanks again for everything.
much appreciated
