CEL
plumber
mi.
I have a 1993 SHO. Should CEL be on with KOEO and off with KOER. I also am unable to pull codes.
if you just turn the key to "on" they check engine light will stay illuminated. if it does not, that suggests the bulb is burned out.
if you connect the jumper as shown on the various pages that show you how to pull codes on obd1, then the check engine light will flash. if the light is burned out, you may connect a 12V light, and that light will flash out the codes as well. see:
https://www.troublecodes.net/ford/
plumber
mi.
Thank you for responding. My light does come on with key on but should it go off when trying to start. I'm trying to find out if that could mean a bad PCM. Because I've tried the jumper method and obd1 scanner and I can't pull any codes and the light does not flash. I tried with test light and same result. Thank you Plumber
It should at least return a 111 if there are truly no codes. Maybe post pics of the connector, let's see if it might be damaged at all. OBDI scanners are notorious for their uselessness.
plumber
mi.
KOEO should make the CE light flash the codes. KOER, the light will flash occasionally. CE light comes on with ignition on, off when started. Sounds like you've pulled codes before, but just in case:
http://wiki.wikisho.com/wiki/EEC_Self_Test_Procedure
Code meanings are there as well.
Hello. Yes a month ago I was able to check codes and the cel would flash. Now I can't so I'm worried something happened to my pcm. Are there other reasons for not being able to pull codes ? Thank you Plumber
BaySHO Performance
SF South Bay
plumber
mi.
Whichever, here are the relevant diagrams for both showing the wiring to the 'VIP Data Link Connector' for both. For a 94, not a 93.
Thankyou . I will try to check out wiring later. If you have any ideas let me know. Thanks again Plumber
plumber
mi.
When I probe DLC with test light to battery I get 12v on neg and pos post. Is that normal. The test light just stays on no blinking. Plumber
plumber
mi.
I later tried the 5v ref test on tps and only get 1.95 v.
plumber
mi.
When I connect a test light from DLC connector to battery it lights on either neg or pos post. Is that right?
plumber
mi.
thanks. Now is that 12v on touching test light to either post? Plumber
