Steven Almendarez
1991 model had intermittent no crank, so I verified with the service manual that the cam sensor was bad. Drove it a couple times and then crank no start. Fuel pump was seized up, replaced it and only getting 6V to fuel pump. Couple weeks later, three melted fuses, after a different guy was tinkering with it, while replacing the fuses and verifying the others were correct and in good shape I found some were in the wrong spot. For example, the cluster fuse _5A_ , had a 20A . the owner said he was told something about a common problem of the contacts in the fuse box had a thinner gauge of metal used in them that heated up and caused electrical issues?
Anyone ever here of a problem with the fuse box heating up causing a reduction in voltage to the fuel pump causing a crank/no start?
