Ia key fobs
Laramie Brown
Denver co
I have a 2011 taurus sho non pp I purchased it with only one key fob will a fob from a ford edge or focus or any other car work I would like one with remote start capabilities so I can hopefully enable it in forscan
Sent from my SM-G900V using Tapatalk
Laser411
I bought another key fob, haven't figured out if forscan can do it or not. If you figure it out, please share.
SHOrod
Torrie Tuned
Cedar Rapids, IA
If you find a fob with the same FCC ID as your working fob it should definitely be able to be programmed. I suspect though that one with remote start may be a different FCC ID though, yet still might be able to be programmed. You won't be able to enable the remote start feature with only a fob and Forscan, but you may be able to program the fob. I have only used Autel scan tools to program additional fobs, I've not used Forscan.
Laramie Brown
Denver co
Thanks
