MurseShawn
I have an '89 MTX with 110,00km and a cooling issue. Cooling fans have not been turning on, leading to overheating. Fan does not turn on with AC turned on either. Coolant and Thermostat seems to be good and coolant is cycling through rad. Placed into test mode by bridge test plug to pull OBD -1 codes. Have 24/25/73 codes, none of which seems related to Cooling fans.
Interestingly the fans come on during the test process! This led me to think it was a faulty engine coolant sensor. Replaced with new sensor. This did not resolve the issue. Any thoughts out there? Is it likely the CCRM?
Help!
Help!
