These are some of the original build pics.
Stinger Roadkill on the drivers door. At the time I was running Hybrid Audio Legatia 6s, the Frogs came later. FYI FAST rings are a waste of time, pick up some closed cell insulation tape from Home Depot, cheaper and works better.
Fully deaded door with the MLV visible just about to get the speaker hole cut out.
Speaker baffles for mids in front doors
Original amp mounting on the drivers side trunk bulkhead. You can see the Helix velcoed to the Sony amp. This was running high level form the Sony amp into the Helix. DSR1 wasn't out and PAC didn't support the Taurus yet.
Interior side of the sub baffle and IDQ12s
Drivers side sail panel. Originals were used and fiberglassed. I have since had the factory tweeter grills filled nd the a pillar trim covered with dark grey Alcatera to match the PP steering wheel.
Passenger side sail panel
