sperold
Last to Know
It has a good look, not much different from stock.
The question is.... was it expensive, and was it a hard install?
I lose interest when you have to put the assembly in an oven and pull the front clear glass off, that sounds like something I would screw up.
Is there any change to the harness?
Dave W
Headlight Solution
Portland Oregon
Looks nice, do you have pictures at night
Just the two right now . More to come . The projectors are the Morimoto Mini H1's 7.0 Bi-Xenon. Good examples on the web. I'll put my particulars on soon. I like the feedback but must admit this is my first attempt with any type of social media.
Dave W
Headlight Solution
Portland Oregon
Thanks for the interest. I will have a major info release this summer.
ScotSHO
Lewiston, NY
Awesome, I did a similar retrofit on my CSVT.
Where did you get the clear lenses from? A discoball 95 Taurus?
Jesse Menck
Did you have crystal clear lenses already. Or did you make those?
Dave W
Headlight Solution
Portland Oregon
Dave W
Headlight Solution
Portland Oregon
Is there any change to the harness?[/QUOTE
Dave W
Headlight Solution
Portland Oregon
Taking the cover off sure can be frustrating. The permaseal they use now is really hard to work with. The install wasn't hard at all if you use the stock Morimoto wire harness. The correct one for the 2nd gen is this one.The correct relay wire harness
shobroooo
