Livernois springs versus....
Juicybaka
Ok, so out the gate, first upgrade is going to be springs. Is the 600.00+Livernois overage justified over the H&R springs? We are talking a pieces of steel, right? Thanks for input
Juicybaka
Makes sense, thank you! What about shocks? Stock seem pretty responsive.
bpd1151
Lurking Around
SHOcago 'Burbs
When I did the H&R's, I left the OEM shocks/struts in place. But my mileage was low.
I would suggest, depending on your mileage, you either keep what you have, or consider aftermarket.
If you retain OEM, then understand lowering springs will wear those shocks/struts out that much faster.
I now have Megan coil overs at each corner.
Juicybaka
Thanks for this feedback, much appreciated! So I have 13k miles. How many more miles left on shocks if I were to just install springs?
Also, I looked at this thread you had from awhile back. Are the coil overs now available for 2016. Price for 4? Thank you!
limited02
Olathe, KS
Juicybaka
So for another 400.00, think it makes sense to go with coil over. What else is needed for this install? I read about camber bolts? Thank you
OmaHahn
Omaha
I bought my H&R on Tire Rack I think for like $200 or $260...?? Do a search on this forum for camber bolts - I have plenty of info on those - I just can't recall off the top of my head as I type this, but I highly recommend them.
Juicybaka
So I’ve decided to install the H&R springs. I have the springs and ordered “Specialty Products Company 81280 EZ Cam XR 16mm Adjuster Bolt - Pair”
Is this the correct part to get rear within specs? Thank you
OmaHahn
Omaha
It sure is! And make sure to use Locktite Red!
Juicybaka
Is $760.00 fair price including alignment to install springs?
OmaHahn
Omaha
That's very high! I found a performance / restoration garage, family runs it and they have award winning cars so I know they do quality work. One of the sons did my springs on a Saturday and charged me $200. Then week later after letting springs settle a bit I had Jensen Tire (Midwest Chain) do the alignment for like $80.
Shop around.
bpd1151
Lurking Around
SHOcago 'Burbs
Glad you posted up Oma.....
I was a tick under $350 myself with install and alignment.
Not to shabby given the expenses of living in/around the CHI-Town area.
OmaHahn
Omaha
Not to shabby given the expenses if living in/around the CHI-Town area.
Not to derail this thread but I was born in Chicago and have family there. I have to get back sometime, I very much miss Ribs N Bibs and Harold's chicken!!!
Sho_Ride
Texas
I know for Lou's, you can have it delivered to your door. I've done it a few times here in Kansas because my wife used to live in Chicago not far from Lou Malnati's pizza.
Yes you can @ tasteofchicago.com
They FedEx it overnight on dry ice. I sent one to someone in New York and he said that frozen pizza was better than any fresh NY pizza he's ever had.
Lostneye
NY
Well, it's been 15 years since I had real Chicago deep dish. I'm going to have to place an order.
crystizel
