About to start reassembling intake (with secondary plates, shafts, springs, etc. FINALLY removed) and had noticed a slow leak on the HP steel hose coming out of top of PS pump. I'd wiped it down a few times and even with car off, the leak would return. It's been there long enough that there is plenty of red fluid along top of motor along heads. I can clean that stuff up before reassembling, but considering doing Nimz's upgrade here:
http://v8sho.com/SHO/Power Steering Line.htm
I can swing by Harbor Freight on the way home today, but question:
What was the main reason that Paul did this? As for my leak, could I most likely just get away with adding some Teflon to the threads? I'd seen on some vids that there is an unserviceable o ring that eventually goes bad where you have to replace the whole hose assembly. Maybe this was his reason . . .
