Anonymous
93 MTX heater blowing cold air ...the blower motor is strong but it's not blowing any heat ...it's starting to get too cold in the morning for this anybody else familiar with this problem ?
How do you check the BDA? And get access to ?There are several candidates: blend door actuator, blend door itself, the etac head unit could be bad, the heater core could be plugged, etc.
What is the EATC ?don't mind me askingI concur with BDA. However, they often get sticky long before failing completely. So run the EATC test a few times, and change the EATC from cold to hot temperature settings a few times, and turn it off and on. Try this at different times, especially after driving the car and/or parking in the hot sun which will loosen the old grease in the actuator. Be patient; try for a few days, if necessary. If you are lucky, it will move over to the heat side. Once it moves, you can drop the glovebox and look for a connector (see old posts, but I recall it is white in color) that you can unplug to freeze its position.
The control unit on the center of your dash (the one with the broken push buttons unless you have been really careful)
Okay. Was thinking these things had a failsafe that in the case it did fail it would at least default to defrost so you could still defrost and defog your windshield. Sucks that only way to get to it is to pull the dash out.Bryan, when there is no vacuum to the blend door actuator, it is in the defrost position. However, if the vacuum is working and the eatc or bda is bad, it can stick anywhere, including the full cold position.
I was able to drop the glove box and switch the door by manually moving the actuator either way hot or cold position it's blowing cool airOkay. Was thinking these things had a failsafe that in the case it did fail it would at least default to defrost so you could still defrost and defog your windshield. Sucks that only way to get to it is to pull the dash out.
