SHOtime-95
- Joined
- Sep 1, 2015
- Messages
- 114
- Reaction score
- 29
So my differential pin ejected through the case leaving a couple small holes in it. I posted another thread about it when it happened, and now I'm all ready to get her back on the road. I Finally got another transmission, and ordered a new clutch, since the old one was slipping. I've also order the axle seals on the transmission, a new main seal since its leaking some oil, and a couple other things while I'm at it.
So as of right now, I've got the old transmission out, and I've washed the new (used but not broken) transmission and subframe, and cleaned up all the nuts and bolts. So when my new clutch arrives, she can go right back together. I'm actually quite suprized how smoothly and easy it has been to do this so far. I know a major part of it is the ramp system I built that you see in the pics, but nothing has been unnecessarily hard to remove or unbolt. I guess its because my car it pretty well kept and rust free.
BUT anyway, I have some questions, and would like some advice along the way. My plan is to split the case on my busted transmission, and remove the differential. Then weld around the diff pins that are still in, so that they cannot ever come out, the put it all back together. And if that all goes well, then I will do the same on my new transmission, so that I don't have to worry about this sh** happening again.
Also, since I plan to take the diff out, has anyone heard about these??
https://m.ebay.com/itm/Ford-Taurus-...lip-Differential-Conversion-Kit-/262274423223
I can't seem to find any info on here about them. I would LOVE to have an LSD in my car. Seems like a cheaper rout than going for a quaife. Would love to know how good they are.
Anyways, here are some pics of the project so far.
I really wish I moved that leaf in the first pic. It's really bothering me.
