Grill removal
Bswizz
Can anyone tell me how to remove the grill. I have a 14' . Will I be taking the entire front bumper off?
Also has anyone removed the side skirts before? I have heard that they are snapped in w/ one time use? Or is it one time use on the clips?
TheBadger
Not sure about the side skirts but the front bumper cover has to be removed to take out the grille.
6500rpm
Bumper cover removal is pretty straight forward. If you're changing grills, be sure to black out the actual bumper and any painted surface (as pictured above). Be fairly careful unlocking the tabs on the bumper cover where it wraps around the side to avoid damaging the tabs that hold it in place or it won't lock back in securely. One thing I've found with the GTG grill is that the powder coat is subject to rock chips so keep some gloss black touch up paint on hand, probably the same on any painted metal grill.
