Took the SHO to the track....an...
Aaron Marty
Trying....
Baltimore MD,
i have a 2013 SHO non pp took it to the track last night and ran a 13.24 at 105 mph (best time)(70 degrees out side temp) my mods are colder gapped ngk pluggs, 170 tstat , drop in k&n, 93 oct tune from torrie, 3 bar. i was impressed but "not impressed" i was thinking with all this done i would at least break into the 12s range. what else do you think i need to do, i contacted torrie and he said i need to data log and submit. i guess ill give that a try but i was still thinking i should be in the 12's. and thoughts guys?
mybigsho
new york
I have a 2016 sho tuned by lms.. My first time to the track I was hoping for better times than what I did.. I was running
the same times as you but it kept getting faster.. These cars have to sixty foot to see big gains.. Shallow stage!!
Your car should see 13.0's consistent and 12.90's mine shaft air.. Down pipes adds 3 plus mph. in the big end
and pulls harder mid range..
Aaron Marty
Trying....
Baltimore MD,
yea the next thing will be the down pipes but i wanna get catted ones due to emissions here in maryland. also i was having a hard time understanding what you wrote "mine shaft air" "sixty foot"? what do you mean?
mybigsho
new york
I purchased the catted DP'S.. Mine shaft air <cool dry high barometric pressure>60ft is the first set of numbers on the time slip..
You want to be in the 180's... Anything over 200 absolutely sucks, mid low 190's ok..
JimC
Was at the track yesterday, our 11th annual track rental for www.mustangcollective.com at Thompson Ohio.
2016 SHO with 93 tune by Torrie and 3 bar.
A friend let me take his new GT350 for a pass
Sent from my SM-G930P using Tapatalk
Aaron Marty
Trying....
Baltimore MD,
hey guys thanks for the replys i was at the ceciol drag strip it is bad ass :) and i will post a picture of the time slip when my wife brings the car back. also what catted DP do you recommend?
JimC
What did the GT350 run?
I think his best was a 12.4. He couldn't get any traction on street tires, and the drag radials he ordered they sent the wheels with the wrong off set.
steelgiant5
If using unleashed you have to do revisions, the first tune he sends you is just a safe tune that needs logging to optimize
JimC
What tune are you using?
Unleashed from Torrie. This was the 6th revision after data logging. Didn't see any tweaks needed after data logging this one -but I ran a data log at the track and will send it to Torrie again for another look since it was an all out WOT for a 1/4 mile.
steelgiant5
Must be the altitude or high DA then, that seems to **** track times
shobroooo
