Trying to use factory amp/subs with pioneer head unit
WhiteSHO91
ive got a 91 with the jbl premium sound. when I got it it already had the pioneer head unit installed so I didn't wire it up. the subs do not work and I feel like its because the head unit isnt sending them power. I have the factory head unit but all I can get it to do is light up. no sound whatsoever. what is the easiest way to get the subs to work with the pioneer head unit? alldata wiring diagrams show different wire numbers an colors than what ive got so that's no help.
Pro*banshee
PA, 16066
Are you trying to just turn it on? Do you already have audio signal hooked up?
My favorite way with an aftermarket radio, run a dedicated RCA pair to the rear amp. a lot of the car-specific ones (scoshe comes to mind) have a center wire that I like to tie to the car's accessory power so it comes on with the key-furgeddabout a signal from the radio mate!
avatar28
Nashville, TN
Um, it's been awhile since I put my radio in but my car also had the JBL system and I just tied the radio directly into the speakers. As I recall, there were two sets of harnesses in the dash. One tied into the factory amps, the other goes directly to the speakers. I just used the latter set to drive the speakers directly with the head unit. I then ran an RCA to the back to connect to my subwoofer amp. I also replaced my speakers with aftermarket ones. I will note, though, that my car was missing the subwoofer so I couldn't tie into that. I don't remember now exactly why I decided to bypass the factory amplifier beyond that.
Mike olsen
I have pretty much the same problem in my 92 sho with the jbls my stock head unit didnt work so i replaced it with a pioneer and i can get the head unit to turn on but i have no sound to any of the speakers
Sent from my LGLS675 using Tapatalk
Mike olsen
I just bought the car from a family member a week ago so any help would be apprieciated
mrecoolgar
SHO NUP
Hershey-PA
You will need to bypass the factory amp.
Use and amp bypass harness.
I have some in stock.
Mike olsen
Do u know how much they cost off hand and withe the bypass will the sub still work
Nomospm
