Madyaks
Madyaks
I live in Missouri, would a 93 octane LMS tune and Downpipe with cats cause a car to fail?
If it does, would going back to the stock tune fix it
not unless it is a really crappy tune. the tune should be set up to run closed loop during most driving conditions, and if so the engine should run at stoic and the cats should clean up whatever is getting to them.
are there any codes?
That is 110% misinformation. The tune can be perfect and still fail, because there are different emissions requirements and testing methods that may cause a vehicle to fail in one county and pass in another.
Texas is a great example. Texas is an emissions state. There are some counties that have emissions testing like Harris or Nueces county that have emissions, BUT there are neighboring counties that do NOT have any emissions testing or regulations.
For another example, there are some states that only test the OBDii port looking for DTC codes, but there are some states like New York and California that not only test the OBDii port but also test the tailpipe with a "sniffer" or tool that measures the levels of emissions that your car is emitting. This extra measure of testing measures what your car outputs VS what the mfgr advertises to the govt with a small "fudge factor" for more.
I am sorry that you and sperold feel that my response was subpar, but it is 110% true. We have an entire engineering team that works with all of the major automakers. We engineer our own software, hardware, tooling, parts and products. We know for a fact that our tuning with the exhaust products that we make will not pass emissions. We know that the cell count of our specially designed race style catalyst and the catalyst location will cause any vehicle fitted with our downpipes whether it be with our race cats or without will fail emissions testing. Also if there is a readiness test that is done on a car that has these modifications done it will also fail. Are there a few outliers that exist, sure, but we do not advertise as such for the simple reason that more cars will fail than pass.
Wow.
Why would your tune not pass the readiness test after the appropriate time?
Why would you bother to build and sell a cat that you know won't pass emissions?
