I will be so happy to have my SHO back
BigB15
GA
Took it in for the Hubs TSB and a paint defect.
Turns out the Pearl is tricky, tiny defect on the driver door spine= both doors getting repainted. I hope they get it right
Dealer put me in a 300s rental, which is better than a Fiesta, but still not on the same level.
Now on work travel driving a equinox, what a POS.
I guess the good, is that it will be like the 1st time I drove it all over, and I can put the tune back on.
Stock will be great , Tuned will be back to perma-grine.
I have to say it again, this equinox is a crap box.
Gives you the opportunity to re-appreciate your SHO :) Hope they get the paint job right. Blending is an art. Having the hubs corrected = money!
setaonivek
What hub tsb and what year does it affect.. I am going in for my first service and want all that stuff taken care of ..
Sent from my SM-N910W8 using Tapatalk
setaonivek
What hub tsb and what year does it affect.. I am going in for my first service and want all that stuff taken care of .. I too have a paint defect on the passenger side rear pillar above the door..
TSB 14-0186
Ting, Pop or Click Noise From the Front Wheel Area When Accelerating From a Stop, on Turns or When Shifting Between Drive/Reverse and/or Reverse/Drive – 2011-2015 Ford & Lincoln Vehicles
Publication Date: October 6, 2014
FORD:
2011-2014 Flex
2011-2015 Explorer, Taurus
LINCOLN: 2011-2014 MKS, MKT
This article supersedes TSB 13-5-14 to update the vehicle model years, Issue Statement and Part List.
ISSUE:
Some 2011-2015 Explorer, Taurus, 2011-2014 Flex, MKT and MKS vehicles may exhibit a noise that could be described as ting, pop or click noise from the front wheel area when accelerating from a stop, on turns or when shifting between drive/reverse and/or reverse/drive.
ACTION:
Follow the Service Procedure Steps to correct the condition.
SERVICE PROCEDURE
  1. Separate the halfshaft from the wheel hub. Refer to Workshop Manual (WSM), Section 205-04.
    1. Do not remove the halfshafts from the transmission or power transfer unit (PTU).
  1. Install one (1) thrust washer, metal surface first, over the halfshaft splines until the metal ring is flat against the wheel bearing mating surface. The nylon surface should face outward toward the hub/splines. (Figures 1 and 2)
    Figure 1 – 14-0186
    Figure 2 – 14-0186
  1. Install the halfshaft to wheel hub. Refer to WSM, Section 205-04.
PART NUMBER PART NAME
BB5Z-7G273-B Washer – Thrust
W712435-S439 NutWheel Hub
W714890-S440 NutBall Joint
W713968-S440 NutSway Bar Link
W714890-S440 NutTie Rod End
W500220-S439 BoltDynamic Suspension
OPERATION DESCRIPTION TIME
140186A 2011-2014 MKT, MKS: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.8 Hr.
140186B 2011-2014 MKT, MKS: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.2 Hrs.
140186C 2011-2014 Flex 2011-2015 Taurus: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.7 Hr.
140186D 2011-2014 Flex 2011-2015 Taurus: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.1 Hrs.
140186E 2011-2015 Explorer: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.7 Hr.
140186F 2011-2015 Explorer: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.0 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
3B436 42
13blacksho
Des Moines IA
TSB 14-0186
FORD:
2011-2014 Flex
ISSUE:
ACTION:
SERVICE PROCEDURE
    Figure 1 – 14-0186
    Figure 2 – 14-0186
WARRANTY STATUS
DEALER CODING
3B436 42
Good to hear!!!
My car has this sometimes strong "pop" when doing a three point turn around or even backing into a parking spot.
Are TSB's covered under 60,000 miles?
TSB coverage is listed at the end of the TSB text. So in this case, only during B2B coverage, not powertrain. BUT, if the parts involved are normally considered part of the powertrain, then yes the TSB cost would be covered.
I'd have to pull up powertrain coverage info to see if there's any on the halfshaft ... let me see ...
EDIT: Looks like you have coverage per this Ford document, pg 10+
http://www.ford.com/resources/ford/general/pdf/2013Warranty.pdf
  • Ford2013Warranty_newvehicle&powertrainwarranty.pdf
Hebes10
Pittsburgh, PA
TSB 14-0186
FORD:
2011-2014 Flex
ISSUE:
ACTION:
SERVICE PROCEDURE
    Figure 1 – 14-0186
    Figure 2 – 14-0186
WARRANTY STATUS
DEALER CODING
3B436 42
I tried to order the thrust washer (BB5Z-7G273-B) but my local Ford Parts center told me that part has been discontinued and replaced with F2GZ-7G273-A. But the parts seem so different , with the original washer having a nylon side and the new part looks like a big internal tooth lock washer. I can't find any info that shows the old part was replaced, nor an updated TSB. Is this info available online?
Brad kirk
