Livernois Tune Package
Joe Caughel
Hello All!
I was thinking about going with the tune package listed below. I was wondering (as a non mechanic type guy and learning new things every day) if this stuff is an easy install or should I have them do it? Also, my 2013 SHO has 60k miles, are these tunes good for an engine with that many miles or should I be concerned. Thank you all!
http://www.livernoismotorsports.com...rmostat-{47}-Thunderstorm-Downpipe-Combo.html
-Joe Caughel
The downpipes require access to jackstands or a lift, and there probably will be some armwrestling with the bolts & studs holding the DPs on. The rest is topside, and can be done with relative ease.
The tunes are fine for a 60K engine. But first you should run through the maintenance checks like hoses tightened down and not leaking, trans/PTU fluid check/change, intake/intercooler verified to be relatively free of oil/crud, etc.
ridered74
And after all that......DO IT!!!! The difference is amazing.
Gotta be honest, I am still hesitant to look into the downpipe. 10-15 HP sounds great, but I do NOT want any extra sound whatsoever during normal driving/cruise, and I just dont see this being possible.
SHOnUup4
SE MI
Only extra noise I hear from catless downpipes is at low rpms...and it's just turbo whistle
Rich
