SHOspazz92
Banned
The car has every single performance item imaginable except for forced induction. My listed prices are Firm but priced fairly. Shipping would not be included in the pricing - Items include:
Millie Miglia Sfera - 17x8 + 40 Wheels. Very rare. Minor belmishes, otherwise in good shape when cleaned up. Currently have tires on them with lots of tread, however one is flat-spotted. - $400
SOLD ITEMS
SHOsource CC Plates - SOLD
Custom oil Cooler setup with Relocated Filter and all adapters (Very Nice A/N Fittings, stainless lines...etc) - SOLD
Performance Plus Stainless Y-Pipe. - SOLD
Custom 2.5'' Single catback exhaust - Stainless Steel - SOLD
Taylor 8.2mm Thundervolt Wires (Black). Come with a Coil-Pack. Both items have less than 7,000 Miles. - SOLD
220,000 Mile 3.0 with Main and rod bearings that have less then 10,000 miles on them. Engine runs perfect and has SHOnut +20 cams and Swain-Tech Coated stock exhaust manifolds. This engine was gone through before being put in to the car...all seals and bearings were replaced. This engine does not leak a DROP of fluid ANYWHERE. The engine will be complete Minus the Intake manifold. The engine will have a power steering pump and water pump attached, but the pullies will be removed, along with the injectors and fuel rails and starter and A/C compressor. The heads on this engine are exceptionally clean. A new front valve cover gasket will be required (I pulled the front valve cover to see the condition of the head). I will not part out the cams from this engine. - SOLD
Reinforced Front and Rear Motor Mounts - SOLD
Rod Shifter Assembly. Complete and Rust Free and very tight. SOLD
H Brace - Sold
Cobra Brakes/Stainless Lines - 200 (350 with Baer Eradispeed rotors that need new rotor rings) -Sold
BBB/EH intake manifold with shaved bracket mounts and EGR Valve casting. Has a custom spacer that deletes the coolant block. Comes complete with the throttle body, IAC and all solenoids needed to bolt right up to a Non-California MTX right out of the box. Add some paint and some new hoseclamps and you'll have one sharp intake. - SOLD
Carbon Cowl Hood - Needs work, complete - Sold
X2J Computer - Sold
ZEX 82011 Nitrous Kit - 250 Dollars - Sold
Gen III Sub-frame with ZF Rack, 22mm Swaybar with Moog Greaseable endlinks and low mileage Control Arm Bushings. I would suggest replacing the Ball-joints. Knuckles may be included but I would suggest replacing the wheel bearings. - SOLD
TwEECer R/T - 300 - Currently tuned for a 3.0 with SHOnut +20 cams and a 80mm MAF. This tune is very aggressive on the timing curve. Run the current tune at your own risk, otherwise just download the software from Josh's website and re-tune. - SOLD
SHOshop 3 Peice UDP's (PS/WP/ALT) - SOLD
Adjustable Rear Control Arms - SOLD
Quaifed Transmission - Shifts PERFECT. - 1300 - Sold
Ground Control Coilovers with good Konis. - 500 - Sold
Jose Short Shifter with Braces - 275 - Sold
SHOshop Carbon Fiber Can with 80mm Fenderwell Horn - Comes with Filter- SOLD
Custom Alternator Bracket that completely removes the the A/C compressor - SOLD
I'm sure I'm forgetting a lot more.
SOLD ITEMS
H Brace - Sold
X2J Computer - Sold
