Bryan
What do you get when a deer & SHO cross at 45mph?
Okay I finally got the valve covers off and checked them (thank you SHOPhoenix Project!). And I have to say it seems no oil is leaking out from the valve covers. Also the third bolt on the valve cover (closes to the fire wall) will not fully tighten. It gets somewhat tight, but I feel I am only going to round off the hole if I try to tighten it anymore. I drove it around and seemly it is not leaking from that point so I am going to leave it as it is.
The bad news is the car is still smoking. So whats my next move? I see reading from the forums here that cam seals and the crank sensor (as well as the oil too) are known points for oil to leak. I guess I should check these out as well?
