Megan Coilover installation for 2009-2012 SHO
EcoPowerParts
AZ
This is a Flex but same install for the SHO.
I received my coilovers last week in this pretty box :)
IMG 0666
IMG 0667
Front Strut:
IMG 0668
Rear shock:
IMG 0669
Factory rear shock spring setup:
IMG 0687
Rear install instructions:
Remove the end link here:
IMG 0688
IMG 0689
Remove lower shock and control arm bolts:
IMG 0691
IMG 0692
Factory spring vs Megan adjustable height spring:
IMG 0693
Reinstall Megan spring and adjust with adjust side up, make sure to reuse the factory rubber pads:
IMG 0694
IMG 0695
Remove the stock upper bolt, in the Flex it's underneath these cubbies. To remove the cubby remove the 4 screws then lift the front of it up while spinning the rear out from under the lip in the back. It took is a couple of minutes to figure out how to get that done.
IMG 0696
Remove the nut under the flaps:
IMG 0698
IMG 0699
Remove the factory rubber from the top nut
IMG 0701
Re-use the factory ruber and install on the shock, the bottom rubber goes under the car, the top rubber then is installed from the top of the car with the nut and washer.
IMG 0700
Reinstall the factory bolt and utilize the new nut supplied from Megan. For my car the nut was not the same size as the factory bolt so I had to go pick up a new one, we did not get the size of the nut but I will inform Megan so they know.
Completely installed rear:
IMG 0708
IMG 0709
EcoPowerParts
AZ
Front strut time!
IMG 0704
IMG 0705
IMG 0705
OK I didn't get a picture of the front dissembly but it was not fun at all. The left side we tried to just force down the front suspension once the strut was unbolted, eventually it worked but not a clean way.
Correct way:
Remove axle nut
Remove control arm to spidle nut
Remove control arm to steering linkage
Remove spindle to strut bolt in the rear.
To make the whole assembly lighter, remove the brake caliper from the spindle, now pull down on A arm and pull the spindle off of the axle and the bottom of the strut.
Remove 4 nuts holding stock strut.
Install Megan coilover into the spindle and reinstall the spindle on the car.
Push Megan coilover up through the top holes and install new nuts.
For my car the Megan hole for the factory sway bar linkage was too small, we had to drill it out with a 9/16 bit. - I will inform them of this, either bigger hole or supply a new bolt that fits.
Remove the sway bar end link from the strut.
IMG 0707
Factory strut vs Megan coilover:
IMG 0712
IMG 0713
This is how the car sat on 17" wheels with 26" tall tires, The rear was adjusted all the way up to make as much of rake as possible. I'll post up pictures of the car on 20's with 255/45/20 this week.
IMG 0720
IMG 0723
IMG 0724
Car sitting on the trailer:
IMG 0727
EcoBrick Bob
Clear Lake, IA Naples, Fl
Nice writeup... How much $???? The only thing I would change on your Flex is the color!!! LOL (and initially we tried to get a black on with a silver top...) got stuck with red/white... hence the "Brick" color and look!
EcoPowerParts
AZ
List is $1K, you can get them for mid 800's shipped. I'll try and set up a group buy soon on the EPF
EcoBrick Bob
Did you assist in the install or did your local shop do the installation? If so, how much? Can they be used with the H & R springs I have, or do they replace all that?
EcoPowerParts
AZ
You don't use your H&R springs with this kit, you would sell those.
I worked side by side with the guy at the shop, he's a buddy of mine, we've been working together the whole time on the work being done.
EcoBrick Bob
Did you previously have either H & R or Eibach lowering springs? If so, how much different is the ride and handling. My ride is considerably stiffer with H & R, but not harsh, and I run 40 lbs or more air in tires. Handling is better than stock G8, even with 60K on Flex. H & R's plus installation was around $550. + alignment.
Is there considerable adjustment on these, considering the big weight difference between SHO & Flex?
EcoPowerParts
AZ
Yes, I had H&R springs, I don't know what the difference is because I need to put my 20's back on and adjust for those. :)
There is huge adjustability in these coilovers. Darreli just installed a set on his car, he did a write up on my forum, you should come back and reply there.....
EcoBrick Bob
Think I need a new EB vehicle to test these... at 60K... not ready to spend those $$$$ considering how great the Flex is ... as is... If I were to start over.. this would be one of my first investmets... Mike.... Thanks!
Next EB vehicle... 2015 Flex or heaven forbid..... a low mile MKT... Money is tight these days.. hopefully by next year... I will be flush like it used to be.... SUKS...
EcoPowerParts
AZ
Initial review of the coilovers?
One word, AWESOME!
One million percent better than stock or the H&R's. The car corners flat as a board, absorbs all of the bumps that would cause the H&R to "see saw" and just ride awesome. I haven't really done anything other than adjust the ride height and set to 5 clicks stiffer from full soft. I have more adjustments to make and I think I can get it much better, need to play with shock adjustments and coil preload.
Couple of videos after getting the 20's back on and the height adjusted. This is all the way down for the fronts, rear could drop another 2" or so.
http://www.youtube.com/watch?v=s5IJNKM6zlA
This video is riding on the Megans and testing the aux fuel system activation and cutout
http://www.youtube.com/watch?v=7hFtOEfRC6c
I need to take another video of an onramp that is a 270 degree 25mph ramp. The car was completely flat and wanted to corner at 50MPH without even flinching, AMAZING!
