abs to non-abs.
sho4life
midwest
Can I use one port for front and one for rear? Are both ports equal pressure? Can I hook up just the fronts to the two ports? Otherwise I need t-adapters? Thanks
Racer X
SHO Pilot, Retired
Connecticut
There are like 3 recent threads that discuss this, did you even search?
No. No, you didn't search.
Unless the car is going to be track only, don't do a F/R split, lest something go wrong and you **** someone.
Racer X
SHO Pilot, Retired
Connecticut
I'm on my cell phone. Cant search
Odd, I can search from my cell phone. ****, I could search from my first gen BB curve back when I had it.
I'm calling shenanigans on your inability to search.
sho4life
midwest
I checked all the posts. I still cant find out if and what will happen if I run the front brakes seperatley to each of the two ports and totally bypass the rear. what will happen if I hook up the lines to the stock booster and mc?
93markVIII
MO
what the ****? why?
the brakes on a sho work just fine.
our 92 with the 11.6 front rotors and stock rear would lock all four tires without an issue.
the ABS would go off all the time.
what on earth are you trying to do?
go buy a honda to screw up.
93markVIII
MO
why? there is nothing wrong with a functioning ABS system.
SHO1
Coke Is It!
The State Of Hockey
Talk to Zach, he just converted abs to non-abs.
And some people just prefer no abs, I suppose mainly people that drove alot of years w/o it before it came along. and if it isn't working it may be easier/cheaper to delete than fix. I much prefer my non-abs '89 over my abs '93 for MN winter driving.
sho4life
midwest
I don't have time money and parts to fix the big nasty octopuss. The rears currently don't work anyways. If no one had any info then I guess I'll just hook up direct lines from the fronts to the two ports. I plugged the abs oil line. Hope I don't **** myself with a trial and error
zach44102
BIG TURBO
Georgia
Ok well ill try not to be a total dick and will try to explain things.
I converted my drag car from ABS to Non ABS because it free's up space in the engine compartment, removes a LOT of wiring from under the hood and Drops the weight a little bit.
The easiest way is to find a NON ABS Taurus Doner car. and use the Booster, master cylinder and all the hard brake lines from the master all the way to the rear proportioning valve.
here is some pics.
Abs lines on left, non abs on the right.
A5C0 34EC60708D87 442 000000BA2C24A054 zpsb14d3c49
89E2 83DED9B7F59D 442 000000BA31F81915 zps045c2e69
867E DB5E5B84138D 442 000000BA371F158D zps461e32fd
96C2 2990970BD2A7 442 000000BA3D150811 zps3727d930
B91A C8D9CFD604D7 442 000000BA42F27AD4 zps514337c2
SHO1
Coke Is It!
The State Of Hockey
Both rears don't work at all as in no braking in the rear? That could possibly be caused by a bad proportioning valve in the rear or the hoses pinched off from rust at the clamp that holds them to strut.
Racer X
SHO Pilot, Retired
Connecticut
Why would you even want to do this?
What the actual ****...
No one gives two ***** about you Darwining yourself, but we do care about the innocents out there who weren't able to get out of the way of your stupidity in time and end up hurt as a result.
I really, really wish I knew where you lived, I'd drop dime on you to your local PD myself.
Fix your brakes properly, and if you can't afford to, stop driving the car until you can. Your stupidity is going to get someone killed.
Zach, I was all impressed that you had figured out that rats nest of brake lines all by yourself. Then I saw the purple subframe....
zach44102
BIG TURBO
Georgia
I picked up a tenth in the 1/4 with purple runners. So my logic says purple makes you faster
sho4life
midwest
Just asking how to bypass abs and hook it up so its safe. The guys at the repair shop helped me. It works great.
I really did laugh out loud at that. The purple subframe must have saved you another two tenths, right?
sho4life
midwest
2 Ports two tees. U don't need to buy a new master cylinder. Info for people that don't know.
