Decided to double-check my ground circuits for PCM and sensors since I forgot to tie the #40 & 60 PCM grounds directly to the body at the battery - terminal cable. Fixed this, but still no reset of PCM.
So I set about checking the ground circuits for the PCM and sensors. I did two separate tests with the PCM connector (PCM disconnected), Ignition switch OFF, and CPP switch OFF (open).
Test A) DVOM positive connected to batt +, and checked volts at each ground position.
Test B) DVOM positive connected to batt -, and check for continuity at each ground position.
Then I went around the PCM connector looking for any other circuits that might be tying (shorting) to ground. Here's what I found:
OK, here's what I don't understand:
This is driving me nuts! I must really have something f#^&ed up.
- PCM #60, 49, 40 - all good
- Sensors: all good
- ICMR #15 (BK/LG)
- MAF (BK/LG)
- Ref Cont SW/ICMR #17
- O2 #1 & #2 (BK/LG)
- PCM #60, 49, 40 & sensors - all good
- #9 - MAF (T/LB) Grounded by PCM --> OK B & C inside MAF have continuity & goes to ground.
- #16 - Ignition ground (O/R) --> OK Ground is passed within DIS module connectors.
- #17 - Data Link conn/Malfunction lite (T/R) --> OK Appears to ground through the Crank Pos Sensor.
- #19 - FP Mon (PK/BK) --> OK Circuit closed by FP motor
- #20 - Gnd --> OK
- #30 - Clutch Pedal Position sw (P/Y) --> OK Corrected wrong connections
- MAF #9 - If I check continuity between signal (D) & return (C) on the MAF I get nothing - which makes sense. When I check between return (C) & ground (B) I get continuity. Isn't the PCM supposed to supply the ground side of the return. If return is connected internally in the MAF what will the PCM detect?
- #16 Ignition ground - This leads to the CID, Crank position sensor, and the ICM (DIS). I don't see any connection to ground, so one of these must be grounding this circuit internally right?
- #17 Data Link - the EVTM indicates this is supposed to be a 12V circuit to the data link connector and Malfunction lite. How could it be on the ground circuit?
- #19 FP Monitor - this circuit ties to PCM #5, the FP & cut-off switch (which I'm not using yet), and then to ground through the FP. With the FP off I should not be getting to ground.
- #30 CPP - this circuit goes to numerous sensors (via GY/R wire) when the switch is closed, but mine was open.
