SHObogdan1
Hi everyone, I posted before regarding idle issues on my 93 ATX and it seems like its probably due to a bad IAC. This past month or so I haven't had the chance to replace it because I've done a lot of body work to repair rust on the car. I finally finished the job so I drove it around for a couple of days and I noticed a loud rattle coming from the serpentine belt area and guessed it might have been the alternator. When I decided to check it out, I opened the hood and the pulley directly below the alternator was wobbling really badly. Also when I turned the A/C on max the car would stall while idling. So is it safe to say that my A/C compressor/clutch is toast? Could it also cause the inconsistent idle I've been experiencing? When the engine is fully warmed up (and the A/C is off) the car runs really well so I don't think I have a vacuum leak anywhere.
-Just to note: the A/C does work and the CEL isn't on so that doesn't help point me in a direction.
