Super 8 Discount Code for the BBQ
Irish Pride
Irish Inside
MusicCityUSA
I just booked my room at the Super 8 down the road from Daves. Before i did i searched online to see if i could find any way to get it cheaper. Sure enough i stumbled across a code to get 20% off. I just booked my room for $39 a night.
Go to www.super8.com and put in your destination and select your dates and then search. In this case when the selections for St Louis come up, scroll down to #3 which is Super 8 Airport. Select that one and when the next screen appears scroll down till you see a box marked Corportate Code on the right. Then enter "1000006356" in that box and hit Check Rates. It automatically takes 20% off. When i travel i tend to be a cheap SOB on rooms and this made me happier than a pig with two peters!!
Irish Pride
Irish Inside
MusicCityUSA
Bump.
This code still works but the rates have gone up from last year or there is something special going on in town the same weekend as the BBQ causing the rates to be higher.
shoreracer92
Davenport, FL
hey IRISH PRIDE.... Thanks for that corp code. We just used in in Wilmington, NC at a days in. Worked there too. Every saved dollar is a blessing now-a-days! Thanks again bud!!
vortex2450
Buying Parts...
North Carolina
you were in my back yard dude.
Thanks for the code. that's awesome.
-Josh
Irish Pride
Irish Inside
MusicCityUSA
Bump for those needing a room in Saint Louis. The code up top is good for 20% off. You need to book at the "airport" location at 9798 Saint Charles Rock Road.
crystizel
