93-95 ATX Alternator Brushes - FOUND!
NoSlo
SHO Owner
Portland, OR
After looking at tons of catalogs and listings, I've found new brushes for ATX GenII SHO alternators! They are $6.50 each (P/N 38-8307 - two needed), or $3.xx for the version without the terminal or spring (P/N 38-8305). Available from Romaine Electric - 800-426-5005. I was getting tired of third-world rebuilt alternators dying after two years when the original lasted 12, so decided I needed to take action!
75% of alternator death is likely brush failure, as you can see in the pic below, the never-rebuilt F3DU-10300-CB Mitsubishi-made alternator ran fine until the brushes wore down to the limit.
Original Mitsubishi brush worn to wear limit line, two styles of replacement brushes:
Sho alt brushes
Voltage regulator assembly includes brushes, costs nearly as much as a rebuilt alternator:
Sho alt regulator
I stopped searching after finding these aftermarket, but it's possible that you might find Mitsubishi-made brushes if someone wants to go bother other car dealers, since the same brushes seem to be used in several models of Mitsubishi-made alternators:
Original Mitsubishi part number:A647X50170
Ford Part number: F1CZ-10347-A
Carquest: 20-1625
Possible matches, alternators that use same brush:
-with solder terminal
Eagle Summit 1.5L 1995-1996
Eagle Summit 1.8L 1995-1996
Mitsubishi Expo 2.4L 1994
Mazda 3 2.0L, 2.3L 2004-2008
Mazda 5 2.3L 2004-2006
-without solder terminal
Mitsubishi 3000GT 1991-1995
Dodge Stealth 1991-1995
Mazda 323, 626, 929 1990-1991
B2200 1987-1993
Note, brushes might not be the cause of your dead alternator, I have one in my collection that has a stator coil winding short to the case, use the Ford CD or shop manual diagnostic procedures to check all the parts.
Sho alternator diagram
1a - 10B304 - Nut
2 - Washer
3 - 10344 - Pulley
4 - 10A335 - Bearing front screw x4
5B - through-bolt x4
6 - 10333 - Generator front housing
7 - 10A303 - Generator front bearing
8 - 10A355 - Front bearing retainer
9 - 10335 - Rotor
10 - 10383 - Stator terminal
11 - 10334 - Rear housing and bearing
12 - 10304 - Rectifier
13 - 10347 - Brush and terminal x2
14 - 10316 - Regulator
15 - 10336 - Stator and coil
Partial disassembly to replace brushes:
-Remove Four through-bolts
-Heat center of alternator back with 200w soldering iron (or on stove) to release pressed bearing
-Split alternator with screwdrivers about 1/4 inch
-If stator is stuck to front of alternator, pry it loose from front through split
-Finish splitting halves and remove front assembly with rotor
-Remove the two philips regulator screws (use impact driver if stuck, do not strip)
-De-solder the two tabs between the regulator and rectifier. You may need to straighten the crimped "forks".
-Remove regulator
-remove back-plate and brush cover clip from regulator
-de-solder brush terminals
When reassembling, push brushes in and stick a wire in hole in back of alternator to retain brushes. Reheat alternator back while assembling.
SHOtimer
#2910
Santa Clarita, Ca
...i've been waiting for this to be a problem with my SHO. I'm 106 miles shy of 250k, original alternator.
Doug
AREA 91
Area 91
This is GREAT!!!
Now, can you post the pat number's for the SHO 3.0 90 AMP?
:wave:
Phoenix
SHOHOLIC
QC , Canada
This needs to be schticky.
NoSlo
SHO Owner
Portland, OR
Just a note, I had to elongate the holes in the brushes towards the center a bit to match the holes in the housing that you put a paper clip in to retract the brushes while assembling. No big whoop. Soon I will have two extra rebuilt alternators with new brushes and one real dud of a core to return for my lifetime warranty replacement if all goes well. I'll put a few hundred testing miles on them and maybe sell one...
