MAF from VMP tuning.
Injectors from Lightning Force Performance.
Are you going with E-85,Tim?
80 lbs should be fun. They're almost as big as what's in my STi, but I'm down 2 cylinders. I need to see if Injector Dynamics makes something that'll fit the SHO.
Doubt it. On E85 those wouldn't be good for much more than 450hp, and then he'd lose "The Challenge" to a stock N/A SHO.
On gas they are good for more like 650hp.
Yup, they do. You can buy anything for a V8 Mustang and remove the adapter caps they have, and they should fit a stock SHO rail. Use them as is for a modded rail. Viper injectors should be the same, and then you'd have 4 left to sell to the 4 banger crowd. I've been keeping my eye out for a cheap set of ID1600s or ID2000s.
There are quite a few fitments of the ID1000's.
Tim, thought you were already running a slot maf from VMP. Are you upping to a 4" housing?
