12.2X.81 TCE Brake Kit??
19sho90
Colorado
I just bought one off tool man! Prolly Should of asked this before but W/E too late now. lol. Can you buy rebuild kits for these?? Like Seals for the pistons? Also what pads can i put on after the existing ones wear out? Ive read its a good kit(Out Dated but still better than the $1200+kit from TCE for now.) I just really want some more info about the kit. Thanks :omgsho:
SHOspazz92
Banned
Triad Area, North Carolina.
Do you mean that its better then spending 1200+ then the current kit, or it is actually a BETTER brake kit then the current kit?
-Sam
zach44102
BIG TURBO
Georgia
Its a very nice kit. Cograts on the purchase. I almost jumped on these before i went to cobras.
19sho90
Colorado
-Sam
The new Kit is by far better. But for the 400$ I spent compared to the $1500 kit out now I don't need that kit this will plenty of Brakes.
19sho90
Colorado
haha, I am sure he means, for the price he paid, its better than spending $1479 on the current offering.
The calipers are four piston FSL's.
Parts found here: http://www.tceperformanceproducts.com/service-parts/
Pads found here:http://www.tceperformanceproducts.com/brake-pads/
Look under the BSL/FSL 20mm - 7420 tab.
Gracias amigo, I'm glad to hear you can still buy parts for it. I may want to stock up in case it end up being like the Rod Bearings have been. (Even though you can buy bearings now!)
yamahaSHO
E85 whore
Arkansas
I think the brake parts will be around for a long time.
Have the powder coated when you rebuild them. :)
Todd TCE
Tempe, AZ
I can pretty much do all the parts from now or in the past. The only item I no longer do is the rotor hat- this was originally the fat hat/spacer set up and I have exhausted them all. Today with most folks not running 16" slicers and all the hats can be "without spacer" you might say. Or the kits can be built with an alternate hat and conventional wheel spacers add to net the same result. I think the first hats were about .935" offset and the shallowest I have now of the TCE parts is .825 making it not quite as wheel friendly.
19sho90
Colorado
I do plan on it! Im partial to a Green Ice powder coat or the classic Red. Not sure yet as of now im just going to paint then Red or Green! Still not sure!
19sho90
Colorado
Sweet thanks Todd! I will be sure to purchase a few parts for a rebuild. Im thinking of doing it anyways so i have fresh Seals and Whatnot on the Calipers. Which Caliper did this kit come with? So i know what parts to purchase!
