vortex2450
Buying Parts...
Hey guys,
I've noticed that my mileage has been lacking as of the past month or so, I recently pumped 3.97 gallons in moving the needle up two marks to the 3/8 mark, I've only driven 67 miles and the needle is back on the "E" mark and the light is back on.
67/4 = 16.75 mpg. :|
I drove highway miles 100% of the time, I never let the rpm's over 3k and engine brake into every stop light and try to avoid full stops as best I can.
I ran for KOEO and KOER codes and none popped up.
I run 89 octane.
The alignment was just done.
Just replaced the timing belt tensioner and timed everything up the the 3.0 marks as usual.
I do let the car warm up about 5 minutes on mornings colder than 50 degree before I drive but I don't see how I can be sucking up so much gas this way.
I was under the impression that leaving the car in gear while coasting into a stoplight saves gas but maybe the injectors are still firing?
Also, the car has a 93' Cobra MAF on it, I tried to swap this out for a stocker but it run like total crap. There appears to be no LPM installed.
Any common areas for loss of efficiency I should pay more attention too?
Thanks,
josh
I run 89 octane.
Thanks,
josh
