power stearing pulley?
wingtip80
delaware
My power strearing pulley is wobbling. Can I just replace the bearing? If so how hard are they to find if at all? Or do I need to replace the whole pump.
Thanks in advance
jimtash
nc
Don't know if there's a rebuild kit for the pump.
you should first look at the pulley - every one that I have seen with a wobble was due to a bent pulley.
if the prior owner didn't know how to get the pulley off, it is easy to bend by prying it.
turbo79
Saint Helens, Oregon
I'll second that, true on many Fords from this era. Hint: buy and use a proper pulley remover and then an installer (not the same tool). Voice of experience here...
shotime1994
AirHammerAndrew
New York
No puller required on the sho to remove the pulley. If the pump is bad just replace it. It takes about an hour to change the pump with proper tools.
turbo79
Thx, I've only had to change pullies on my '89 F250 and '93 3.0 Taurus GL, so I speculated that a SHO might be the same.
wingtip80
delaware
The pump works fine it's just the pulley. I didn't know if it was just a bearing I could change out.
Also the car is a 90
