Old PBR corvette rotor brake setup.
Toul
Columbia, SC
So I finally bite the bullet and buy a remanned set of cobra's with brackets. But for some reason, my drivers side bracket... doesn't effing fit! :bonk:
The bolt holes in the bracket are a size too big. I'm thinking maybe someone stripped the original hole, and heli-coiled it? And that when it got turned in as a core, they pulled out the coil, painted it, and sold it to me.
Anyone ever run into a cobra bracket with a different bolt size? My bracket is stamped with k332-085c-4. Bolt I'm trying to usesays F 10.9 on it, and takes a 15mm socket.
I assume if I take the bracket and correct bolt to a repair shop they should be able to have my bracket heli-coiled within minutes right?
I'm trying to drive from South Carolina to St. Louis tomorrow night. Would have had this buttoned up last night but had some wicked bad storms.
This car is driving me friggin crazy.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
or maybe it was on a crown vic/maurader that use a 14mm bolt vs 12mm for a taurus. see if a 14mm coarse thread bolt fits the bracket. helicoils use the same threads per inch/mm as the bolt hole they are repairing, so an actual larger bolt in a "helicoiled" hole won't fit as the threads per inch/mm increase when going to a larger size bolt. in other words, if a hole is taped for a helicoil to be put in, no bolts will fit the hole.
the 10.9 number is the bolt hardness, has nothing to do with size.
Perry
pjtoledo
'ol man in the SHO
toledo,ohio,usa
not necessarily, if its a 14x2.0 hole you cannot put a 12x1.75 helicoil in it.
n8rsk8r
Hey Where's my post?
Olathe, Kansas
it is so funny to see what kind of combinations you can come up with to put together to stop a car.
I just did a drum to disc conversion on my dime (S10). It has 88-91 Lincoln calipers, has splash shields from a Ford 8"/9" axle, has astro van brackets for mounting the calipers, and T-Bird brake pads...
P5290714
P5310864
P5310874
P5310858
P5310876
just goes to show you... you don't have to be brand/make specific to get the end results. Parts don't know they are GM or Ford or Audi or whatever..
BTW this is the SummitRacing disc conversion kit that is actually made by SSBC.
n8rsk8r
Olathe, Kansas
Hey thanks tool cause those are the colors of my logo for my business.. and peak from the rims. I didn't do it for you but thanks for your input!
Cheers!
