So I installed some Airlift air coils in the rear of the car today. I was originally going to try some spring rubbers but someone told me I should check into some "helper bags" and I found Airlift has a set specific to our car. I wanted to stiffen up the rear end at the track to try to keep the weight on the front wheels for longer. I'm hoping this will allow me to leave a little harder and improve on my 60ft time.
Didnt really need to do an install how-to, they're pretty straight forward, but I know Mike likes how-to's so here it is. (I apologize in advance for the pics, they're from my phone).
1. Jack up the rear of the car and put it on jackstands.
2. Remove the rear wheels.
3. The instructions tell you to remove the shock absorber lower hardware and the swaybar endlink. There are pics of both below. After taking this stuff apart I didnt think I had to on so I tried without it on the otherside....I was wrong...gives just enough space to fit the bags in. (Not gonna lie..they were kinda m'fers to get in there..but with a little patience....)
The nut on the sway bar is 15mm (you also need an open end wrench on the back side) and the shock absorber bolt is 18mm
4. Again, the instructions are pretty good. You now exhaust the air out of the bag, replace the rubber cap on the stem to keep it deflated and squeeze it into the coil spring (This was the hardest part of the install).
5. After you get it in there its time to route the airlines. On our car we have a hole in the top of the upper control arm so you place the bag "stem up" and the airline feeds through the top. They are hooked to the bag over a barbed stem and spring clamped on.
6. I ran the airlines across the control arm and into the spare tire well. Here's a pic with one valve installed and a hole on the other side.
I installed it here because if they work like I want them to I may put a on board compressor in this space as well and run a wireless controller. After the install it's so easy to just hook a compressor up here at the track if I want. Takes about 1 second to inflate to 35 psi (Max) so I'm thinking I will probably skip the controller all together.
7. That's about it...connect the rear shock absorber (a jack under the control arm helps here) torque that bolt to 129 ft/lbs. and connect the sway bar 60 ft/lbs
8. Lower the car back down and inflate the bags to 35psi and check for leaks. Raises the car, maybe, 1/2 inch with the airbags fully inflated.
