Since 1992 I have been the proud owner of 11 different Gen.1&2 SHO's. I have seen alot of different problems present themselves over the years. I do my own mechanic work on them and I have several Ford mechanic friends that are SHO lovers as well. The following problem with this car has alot of us wondering.....so here goes.
I will keep this short because if I typed everything that has been checked and the reason behind it I could go on for pages. I will give as much info in the shortest way possible.
The car.....1993 SHO with a 5-speed. 200,972 miles.
New rod bearings and rings at 160,000 miles.
Upper end done at 170,000. i.e. valves adjusted, gaskets, plugs, etc.
New fuel pump at 170,000 as well. This is what the other owner had documentation of. I bought the car 600 miles ago as a 'parts' car. Since I could not stand to see a SHO just die I decided to see what was wrong.
When I first took ownership it would start and bearly run. Meaning, if you let it idle or drop below 3500 rpm it would 'flood' and die. I picked it up in Wyoming and somehow made it back to Utah. After much looking I found that the MAF had been changed to one from a Mustang and that the BARO sensor was bad. I put a new BARO sensor in and put the correct MAF in it from another 1993. At this point I also did the crank and cam sensor, seals, water pump, etc.
Now let me describe how it runs and what I have done over the past month to fix it. Now you can start it right up when it is cold. It will jump up to 3000 rpm and sit there for 45 seconds and then take 2 more minutes to come back down to 1100 rpm. It will idle at 1100 for a long time(like 5 minutes or longer.) Yes I have done a idle reset procedure with the computer being cleared. If you have it at an idle(1100 rpm) and you just crack the throttle, it will stumble and die. Sometimes you can crack the throttle and it will rev up but once it does rev up, it will go to an 3000 rpm idle and does not want to come back down to 1100. I am sure you are thinking at this point IAC, just like I was. I got a new one and put it on. Did not fix the problem.
If you take it for a ride here is what you get. Of course the idle is too high so it 'races' along. When you stop the idle is all over the place. It is almost impossible to drive it at any speed and anything under 3000 rpm. If you get above 3000 rpm and 'stand' on it you get a 1-2 second stumble and then it takes off and from 4000 to 7000 rpm it goes like a *****-ape. And then when you have driven for 5 minutes or so the problem of going below 3000 rpm comes back. It dies most of the time if you drop below 3000. Once it dies it smells flooded and pulling the plugs confirms it. Once you **** it when it does this. Restarting it by cranking is almost impossible. Most of the time you have to roll start it along ways to get it to restart. Plugs are black but not fouled and they are new motorcraft ones. Also taking a drive with the MAF unplugged will get the same result. Once restarted it will blow alot of black smoke out and spew stuff out the tailpipes all over the driveway. It is just running way to rich. Plus it uses alot of fuel right now.
Ran the codes and I got a 21, coolant temp sensor out of range. I put a new one in. I am talking about the one in the heater line not the guage. Still same problem. I have several SHO's so I took my 1992 with 110,000 miles that runs perfect and started swapping parts.
Changed the MAF and the IAC(again) from the 92. Same problem.
Then put the BARO sensor and the DIS from the 92 on. Same problem
Put the cam sensor on from the 92 for the fun of it. Same problem.
Checked the ground on the back of the motor and the wiring going to the fuse junction box. Same problem.
Disconnected the vacuum lines and capped off vacuum ports. Same problem.
Sprayed starting fluid and carb cleaner over entire motor. No leaks, same problem.
Put the throttle position sensor from 92 and an extra one I had. Same problem.
Checked all wiring harnesses on motor. Including the one on the back of the motor. Same problem.
Changed the CCRM with a known good one. Same problem.
Put in a different computer (behind glove box) Same problem.
Then I thought injector problem since it is flooding so bad. Got 6 different injectors and put them in. Same problem.
Then someone suggested fuel regulator issue. Got a known good one and put it in. Same problem.
Put in new fuel filter. The old one was not plugged. Same problem.
Ran fuel system pressure test. It passed. Same problem.
Took off timing cover to make sure it is still timed properly. It was. Same problem.
The car was test driven each time after I did these items. They were not done all at once and then taken for a ride. Once the parts were put back on the 92 of course it went back to running perfect just like it had before. Also I took a MAF from another 93 I have that is running great. Made sure it was clean and put in on. Same problem.
So there you have it. Why is it running so rich and flooding so bad? Also I did change the temp sensor in the airbox and got the same result. And I did disconnect the o2 sensors and reset the computer just for fun. It ran just a bad as always so I plugged them back in.
Have fun with this..........and I look forward to all your responses! Like I said I wanted to keep it short. Give me a call if you want a more detailed report on a certain item. 435-668-0684. I will check this website each day to see the comments. Thanks to those who keep this website up. It does help us crazy SHO people alot!
