So, for the Chump Car build (and other builds) I am rewiring the engine bay to clean up unneeded things. I'm doing my best to figure out exactly what's needed and what isn't. Most of what I'm doing probably isn't practical for a street car, this isn't another one of the "Can I delete the IAC?" threads.
What's the bare minimum needed for a SHO engine to run properly (track use) on the EEC-IV?
I've deleted/looped back all the SPOUT/VIP/IDM connectors and wiring, that's all useless to me.
Do I need a BAP or no? Not doing hillclimbs, elevation will be fairly consistant.
Do I need O2 sensors? Apparently they aren't used during WOT, as the engine goes into OL. Don't need them during decel either, as the fuel gets cut. Part throttle may need them, but I only care about not running dangerously rich/lean, not about emissions.
On that note, EVAP completely deleted of course.
VSS, needed for an MTX car? I know it's used for cruise control, and that's gone, but is it necessary for anything else?
As far as the list of known needed engine wiring parts goes, so far I've got:
Crank sensor
Cam sensor
Injectors
DIS input/output wires
Fuel pump control
Fan control
ECT
ACT
MAF
IMRC
IAC (if it just did idle, it could be deleted for a track car, but it does decel bypassing as well)
Starter and ignition wires
Knock sensor
Anything else obvious that I'm missing? Obviously I could eventually figure this all out on my own, but having a discussion here may save me some time and help out other people looking at rewiring engine bays or transplanting SHOs.
I'm hoping this thread will be a discussion on the inner workings of the EEC, instead of it just being regarded as a magic box that runs the engine. I think it's useful to know the inner workings and logic behind why the EEC does what it does.
Crank sensor
Cam sensor
Injectors
Fuel pump control
Fan control
ECT
ACT
MAF
IMRC
Knock sensor
