How to tell if your Rodbearings are bad
silkyjohnson
South Dakota
I was wondering how you can tell if your rodbearings are bad, and if there is instructions anywhere on the process. 95atx
LJRuddy
Pop lock n drop
Poaceae fields
Oil light flickering at idle rpm is a good way to tell. When mine went, I heard what sounded like a top end tapping on engine deceleration before the tapping turned into loud bottom end knocking about 50 miles later.
Enzo731
Montreal, Quebec
User CP | FAQ | Community | Calendar | New Posts | Search | Quick Links | Log Out
I really don't know what this guy is getting at?...
They are just letting you know that it's not an uncommon topic of discussion, search button and you will find.
Welcome. It's not so bad once you get to know everyone.
zach44102
BIG TURBO
Georgia
I had a warning oil light flicker at idle last week, Yesterday the car spun a bearing.
zach44102
BIG TURBO
Georgia
nope. I have a 3.2 sitting on a stand with new rb, mb, 3.0 cams, new 3.0 oil pump. I just have to get off my lazy butt and put it in. But i probably need to do vc gaskets, and valve stem seals
zach44102
BIG TURBO
Georgia
Tomorow im going to make a video of the 95. Im going to hold the revs at 7k til it shoots the rod out the oil pan.
AREA 91
Area 91
hows that? the engine is toast anyway.
How do you know? I have heard some nasty knocking yamahammers before. A fresh set of bearings fixed them. If you can hear the piston slapping the combustion chamber, It is junk. If it locks up, it is junk.
SuperHO
Mental Patient
St. Joe, MI
if you can see parts from the inside on the outside without using tools, you may have bad bearings...
tinkerkathleen
