So you can't find the block heater ? *UPDATED*
Unknown_Driver
V6TwinTurboAWD
Ontario Suburbs
so here you are its -31c outside and you can't figure where the block heater plug is on your awesome ford product?
well this is what it looks like it will be located at the front of the engine bay clipped and attached to the front somewhere
IMG 2394
be careful when closing the hood
I plugged the unit into a ****-a-watt meter
the $80(canadian) factory installed block heater uses 466watts and 3.73amps at around 59-60hz
enjoy your awesome starts :salute:
EDIT added a better picture
IMG 2396
SHOrod
Torrie Tuned
Cedar Rapids, IA
FWIW, the 60 Hz is the wall power, not a function of the block heater. You plugged the ****-a-Watt meter in to a 120VAC, 60 Hz socket. ;)
-Rod
SHOrod
Torrie Tuned
Cedar Rapids, IA
I believe UD plugged his into a usage meter to measure actual usage and draw.
C.
Agreed. I was just trying to point out that the 60Hz is not a function of the heater, it's information from the usage meter regarding the source (wall socket) voltage. The current draw is a function of the heater, and the power dissipated is a result of the current draw of the heater and source voltage (120VAC at 60 Hz). I'm not questioning the provided numbers.
-Rod
Fordnatic
Alaska
My window sticker listed a block heater (no charge), but I have yet to find the plug. I keep it in the garage. But I want to locate it, maybe that photo will help me know what to look for. I would have been ****** if the dealer (in Anchorage, AK) didn't add a free block heater to the order!
Showgun
Canuck SHO
Cambridge, Ontario
Yeah... sometimes they're well hidden. Look down low, driver's side, in the grill.
Makes sense that you guys would get one.
C.
Unknown_Driver
V6TwinTurboAWD
Ontario Suburbs
took this just for you :naughty:
IMG 2396
just make sure the engine is off and the fans aren't spinning before you stick your hands in there
Fordnatic
Alaska
Thanks, Unknown Driver! Mine is in the exact same spot. Seems rather obvious now. It was the round cover that fooled me!
