HELP! Need advice. I made a boo boo
zach44102
BIG TURBO
Georgia
Today i decided to put my fstb on and well i think i made a boo boo. tell me whats wrong with this pic.
2vbvcox
If you havent figured it out here ya go
2mo8j0j
My question is. can i drive it too work like this? my other car is gone at the moment and my 89 does not have insurence nor a tag.
zach44102
BIG TURBO
Georgia
Well i guess since i got one opinion im going to take it around the block. thanks will.
p.s i would still like some others feedback
LJRuddy
Pop lock n drop
Poaceae fields
Drive like granny and u should be ok. Wouldn't hurt to check alignment when u get it fixed though
zach44102
BIG TURBO
Georgia
I just drove it around the block everything seemed fine... couldnt really test the fstb quite yet
kevinspann
Don't take my advice.
Richmond VA
This must be why you called me. How the **** did you manage to break the stud off?
If you don't have a spring compressor, get one. While you're there, get a new set of strut mounts...and get me some too; I have the same problem. I've been driving it like this for a while and I've convinced myself can feel the mount rocking back and forth when I push too hard. It's definitely on my list of things to take care of ASAP. It's not a daily driver, though. And I won't be driving it anymore until spring.
To resolve this problem correctly is quite easy, though. I can pull a knuckle in about 17 minutes with the correct hand tools, so I figure another 8 minutes TOPS removing the stabilizer link and pulling the strut out (hey only 2 more nuts, right?), 6:00 to remove the old mount and install the new one and a half hour putting it all back together.
Autozone is open for another 2 hours or so. You can be done by then. :biggrin:
Edit: 17 minutes is WAY too long.
zach44102
BIG TURBO
Georgia
Well im pulling the tokico, eibach of my 89 and while im doing it im putting in new strutmounts. just 1 reason i should do it sooner
one of my current cars has the same stud broken on the rh strut mount. it has been that way for over a year with no issues. of course, it doesn't get driven like Zach drives.....
zach44102
BIG TURBO
Georgia
I actually dont beat on the car like i use too. Do you wanna know how to keep your gas milage up and parts breaking down? Buy a catless y pipe and cut off yourr mufflers, you wont want to hit the gas.
zach44102
BIG TURBO
Georgia
Do you think with cut eibach's i should get the moog adjustable front strutmounts?
