stalled while driving. out of town need ideas.. its cold out
shotyme92
WOT :)
Forest City, IA
Was driving down the road and the car stalled for a few seconds the started back up. I drive an mtx so I just kinda let it roll in 5th. Another ten miles down the road it stalled again, no restart though. I sat for ten minutes and it started back up and off I went. No more did I get back up to cruising speed it shut off again. It just cranks now and here I sit.
frosho
WOLFMAN
Tyngsboro, MA
Classic symptoms of a failing crank sensor (CPS). It doesn't take much coolant to short it out.
sho_shane
Campbell, TX
I might be wrong, But my car did the EXACT same thing from texas to CA... And I never put coolant in mine either. Might have just started today or could be something else.
SHObill
'The Collector'
Rochester MI-48307Detroit
yea well I was going to say a ground issue OR just give that CCRM a slap to reset the relays. Sometimes they just need a slap! lol
shotyme92
WOT :)
Forest City, IA
Leaky water pump you say... lol. It did it again today. So I ordered a new water pump. Crank position sensor should be ok?
FastAndFurious
Washington
Get a new CPS too. It's probably already messed up, and while you are tearing the front apart, it's always good to change CPS.
frosho
WOLFMAN
Tyngsboro, MA
I was expecting a follow-up post like this. I haven't heard of a DIS causing a stall, unless a plug was loose or something.
Since you're gonna have to pull the front end of the engine apart, you should really consider doing the entire front 60k maintenance - water pump, cam seals, front main seal, timing belt, crank position sensor, and cam position sensor. Accessory belts are optional.
sho_shane
Campbell, TX
LOL Im waiting on my Thanks and Rep Points please. lol :)
Happy to see you are getting the parts to fix. I also agree you need to do the CPS as its a pain to get to. Depending on the last time a T-belt was put in it throw that in and with the crank pullie off id do a new front main for safety. :D
shotyme92
WOT :)
Forest City, IA
I was hoping for the opposite reply lol. I'm laid off right now and the cash is a little tight. How much of a pain in the ass is the water pump?
tinkerkathleen
