help smoking engine
trevhelton
Yakima, Washington
Hello everyone
I pop something loose in Seattle about 2 months ago. I freaked out on the hill coming up the water front causing the RPMs to hit really high and burning plenty of good rubber and making plenty of noise. So what I think happened is that the valve hit the cover popping it loose. Do to that the SHO is still driving but it is smoking out of the side of the motor by the firewall. It appears to be oil burning very slowly and the anti-freeze isn’t dropping. Also, the anti-freeze is clear of oil. Now that it is getting colder out I notice that when I run the heater it pulls some of the smoke into the car.
I don’t believe I cracked the block. What I am thinking is that I popped one of the old seals and now oil is leaking out of it since the seal won’t reseat just right. But that doesn’t explain why the smoke is coming in thru the vents badly when it is on. Smoke doesn’t appear to leak in when the vent isn’t on or at least not badly. Thinking if I buy both the upper and lower gasket sets from RCM that will fix the problem. What your guys thought. By the way my SHO is a 92 MTX obviously.
No Pics since there is no obvious damage.
Thanks for your guys input.
Trevor
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Your motor is fine.
First thing you need to do is source the leak.
Is it coming from the motor, or the coolant/heater lines.
I see a heater core replacement in your future.
trevhelton
Yakima, Washington
Ok here is the deal. I was talking to twistedmunky tonight. We were talking about my SHO and how I was looking into buying the upp and lower seal sets from RCM. What we discussed what happened to cause it. Then we ended up on the discussion on what fluids I have lost. Well to make a long story short discovered the only fluid I have needed is power steering. I am loosing it on the exhaiust manifold thus causing smoke then it is being pull by the fans. So I gotta verify that is the case tomorrow when it is daytime. Will let you all know for sure when I know.
