ATX Trans leak
ArkySHO
Arkansas
Right now my 95 ATX is getting its tranny pulled for the 3rd time in 2 weeks.... I had the pan seals replaced and while it was down the first time they replaced the tork converter seal or whatever they called it.... I picked it up drove it less than 10 miles and it was pouring out tranny fluid from the bell housing..... they pulled it and replaced the tork seal agin , they said the first one got nicked when it was put in.... I took it back because it had a exahst leak and threw a code for the egr. While it was there they notaced it pouring tranny fluid out of the bell housing agin....Any suggestions?
SeanMc
NoMoSHO
Call me Capt. Obvious, but I think there is a crack in your bellhousing. Or a hose is loose. Get under there and check it out.
jmpSHO2nd
Massachusetts
It's possible your transmission is overheating causing the fluid to leak out of the torque converter seal. Have them check to make sure your trans cooler isn't clogged which they should have already done when it was there the first time. They should have blew out all the lines before reinstalling the trans.
ArkySHO
Arkansas
finding a good SHO machinic to work on one here in Arkansas is a....... Most look under the hood and say WTF... and tell me to take it away..
AREA 91
Area 91
It's possible that there is a burr on the torque convertor.
This would cause the seal to get nicked, resulting in a leak.
SHOtimer
#2910
Santa Clarita, Ca
The bell-housing doesn't hold any fluid. It just houses the TC. A properly working tranny will have a dry bell housing...
Doug
Chuckblvd
Pt Charlotte,FL
The bushing that is behind the seal in the trans might be worn. If that T/C is wobling on the bushing it will cause the seal to leak.
ArkySHO
Arkansas
Thanks SHOtimer, im positive that it shouldnt be there but it looks like it was machined there by a laith.... the new one should be in the car by monday... well see if it leaks too..
