hawkeye18
Sorta cares
That's not a bad idea, and is not all that hard to do. It'd also fix the clock spring problem so you'd have the airbag, cruise and horn working again. The tricky part may be finding one with the same color steering wheel, if you don't want to swap that out.
Compared to the task of completely replacing a steering column, swapping a steering wheel is pretty much cake.
